Larger wheels / tires and ATTS
Old Jan 1, 2005 | 03:31 PM
eLuderTypeS's Avatar
Default Larger wheels / tires and ATTS
Will 18" wheels and tires have a negative affect on the Type SH ATTS system?
Old Jan 1, 2005 | 03:38 PM
99shRIGGS's Avatar
Default Re: Larger wheels / tires and ATTS (eLuderTypeS)
ATTS transfers torque to the wheel being turned upon...therefore if the wheel is bigger it is obviously heavier and has a longer rotation then say a 16 inch wheel...so if the wheel is bigger, heavier, and has a longer rotation then it will put more stress on the atts system which should still be fine but remeber that atts steals a little power...
it should be fine tho cause i have 18 inch roh adrenalines on my type sh and its fine not much of a difference notice in turning jsut in acceleration it slwoed me down a bit. but other then that ull be aright
Old Jan 5, 2005 | 04:17 AM
Yeah, rotational mass is a biatch is'nt it? That's why i've been considering going with some 16x7 rota GT3s instead of the previously planned 18x7.5 Subzeros. This way I'll be able to afford some REALLY sticky tires and a rear anti roll bar.
Old Jan 5, 2005 | 04:19 AM
satan_srv's Avatar
Default Re: Larger wheels / tires and ATTS (99shRIGGS)
18" with 215/35 rubber is roughly the same diameter as 205/50/16 so you are okay on that side...it's not a longer rotation
Old Jan 5, 2005 | 04:33 AM
UA6 BALLER STATUS's Avatar
Default Re: Larger wheels / tires and ATTS (satan_srv)
sorry to hijack the thread but. Do you think lighter wheels would help ATTS?
Old Jan 5, 2005 | 06:33 AM
LowFlyin''s Avatar
Default Re: Larger wheels / tires and ATTS (Type SH)
Probably not...but lighter wheels will help you get more power to the ground.
Old Jan 5, 2005 | 07:44 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Larger wheels / tires and ATTS (LowFlyin')
18" wheels will not negatively affect the ATTS, unless the car is slammed.
hYbRiD EeEkAy
Nov 1, 2007 10:00 AM
Buzzbomb
Oct 27, 2004 10:32 AM
foolintherain617
Aug 12, 2004 01:26 PM
DOHCon15s
Feb 18, 2004 07:36 PM
Vracer111
Feb 19, 2003 09:41 AM
