Do away with Power Steering?
Old Jan 1, 2005 | 03:22 PM
90civicSi VTEC's Avatar
Default Do away with Power Steering?
Personally i do not like to have power steering in my cars because of the feel of the handling and HP gain, i just picked up a 88 prelude Si, what do any of you suggest i should do with whole power steering setup??
Old Jan 1, 2005 | 03:25 PM
Paul H22A4's Avatar
Default Re: Do away with Power Steering? (90civicSi VTEC)
I suggest you do away with it.
Old Jan 1, 2005 | 03:34 PM
Default Re: Do away with Power Steering? (Paul H22A4)
ever done it???
Old Jan 1, 2005 | 03:38 PM
ogabudiah's Avatar
Just cut the belt.
Old Jan 1, 2005 | 03:41 PM
Default Re: Do away with Power Steering? (ogabudiah)
LMAO cut the belt, ever tried to steer a car with power steering the didnt run??? not very easy to do haha
thanks anyways
Old Jan 1, 2005 | 05:14 PM
hon-derr's Avatar
you asked a question and got a simple answer, thats what i did on my prelude..
Old Jan 1, 2005 | 05:40 PM
Default Re: Do away with Power Steering? (hon-derr)
Well i was thinking more along the line of removing the lines, rack and pinion, pump, and whatever else is taking up my space...
Old Jan 1, 2005 | 05:51 PM
Hawkze_2.3's Avatar
Just take out the pump, lines, PS fluid cooler (if you have one), and reservior and loop the lines at the rack so the fluid can still flow freely. I wouldn't take out the rack & pinion...
Old Jan 1, 2005 | 06:06 PM
Default Re: Do away with Power Steering? (Hawkze_2.3)
Couldnt i take the boots off the rack and just leave it like that? would it make it easier steering?? or should i leave the boots on and loop the lines ?
Old Jan 1, 2005 | 09:04 PM
ogabudiah's Avatar
yes loop lines and <U>leave the boots on for sure</U>.
Old Jan 1, 2005 | 09:32 PM
hOndafienD 04's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ogabudiah &raquo;</TD></TR><TR><TD CLASS="quote">yes loop lines and <U>leave the boots on for sure</U>.</TD></TR></TABLE>
why in the world would you remove the boots?
Old Jan 1, 2005 | 09:56 PM
crdcz03's Avatar
Fortune Cookie Member
Default Re: Do away with Power Steering? (hOndafienD 04)
i wouldnt think a 3rd gen would be too hard to turn without powersteering
but i had my (4th gen) ps belt off for like a month and i think that was the hardest month of my life lmao. i didnt mind until i went into a parking lot.
what i want to eventually look into is seeing how the electric power steering works from the s2000's or ep civic's. and seeing how much all that **** weighs and if it would be worth it to put that on intead of the belt driven old school ps
clewis152
Aug 7, 2012 05:01 PM
Hondaphile13
11
Jul 12, 2009 06:39 PM
yoffer
Oct 9, 2008 04:03 PM
bmwpride
Suspension & Brakes
Apr 20, 2008 07:58 PM
busyychild
Feb 22, 2008 02:30 PM
