no spark, coil or dizzy??? plz help
Old Jan 1, 2005 | 02:01 PM
oMek's Avatar
Default no spark, coil or dizzy??? plz help
well my car wont start today so i pulled the plugs and im getting no spark. i took dizzy cap off and cleaned the contacts it and the rotor still no spark.
is there anyway to test if my dizzy is dead or if its just the coil? i already have the coil pulled out
thanks alot for any advice
Old Jan 1, 2005 | 06:31 PM
gt30typer's Avatar
Default Re: no spark, coil or dizzy??? plz help (oMekoneDC2)
Check the resistance in the coil, I think it should be like 75ohms,but I could be mistaken, The factory service manual has the correct procedure and reading. It could also be a bad igniter. I have seen those go bad all of the time.
Old Jan 21, 2005 | 03:55 AM
oMek's Avatar
/ttt
been out of town and car still is busted, i have a volt metter but im not sure what to test.
any help would be wonderfull
Modified by oMekoneDC2 at 9:26 AM 1/21/2005
Old Jan 21, 2005 | 07:06 AM
orangeturbogsr94's Avatar
I had the same problem and I'm 100% sure that it is the ignition coil because I also had no spark and it wouldn't start but like I said I'm 100% sure.
Old Jan 21, 2005 | 07:09 AM
timmy8151's Avatar
Default Re: no spark, coil or dizzy??? plz help (orangeturbogsr94)
You need to use an ohm meter and check the resistance across the primary and secondary connections. The specs should be:
Primary winding resistance
0.6-0.8 ohms
Secondary winding resistance
12.8K- 19.2K ohms
Old Jan 22, 2005 | 09:32 AM
DarkDragon's Avatar
well if it is ur coil get a MSD cap that is moddified for an external coil for better than stock ignition and it wont cost u over 100 bucks
Old Jan 22, 2005 | 01:34 PM
oMek's Avatar
Default Re: no spark, coil or dizzy??? plz help (DarkDragon)
which msd coil would i need? and i just need the coil and the msd cap?
Old Jan 22, 2005 | 06:56 PM
DarkDragon's Avatar
you can get the cap from places on the net, iv seen them online and it comes with the extra coil wire to connect coil to dizzy. Im not sure about the coil u would need since diff ignition systems have diff resistors and things in them but in my mazda i had i used a 8404 Blaster2 coil and it worked fine. Hopefully someone will post that knows more about it
Old Jan 22, 2005 | 07:06 PM
oMek's Avatar
i just bought a autozone coil started right up, thanks guys
Modified by oMekoneDC2 at 10:01 PM 1/22/2005
Old Jan 22, 2005 | 07:17 PM
monkeyboy20's Avatar
hey man
Dec 22, 2010 06:59 AM
egluism33
May 25, 2008 06:17 PM
menappi
Sep 21, 2005 11:39 AM
phildeez
Mar 15, 2002 07:22 PM
