h22a engine codes
Old Dec 31, 2004 | 10:10 PM
Subwarrior's Avatar
Default h22a engine codes
SO I dropped an h22a into my 99 accord. Great combination. Now I have an OBD1 ecu in an OBD2 car. I hooked my scan tool up and obviously I got squat but a linking error in the scanner. So my question is, how do I check my engine codes?
Old Jan 1, 2005 | 07:56 AM
v4lu3s's Avatar
RTFM
count the blinks on the check engine light.
Old Jan 1, 2005 | 02:53 PM
Subwarrior's Avatar
Default Re: (v4lu3s)
There are no blinks. It's a steady light.
Old Jan 2, 2005 | 04:44 AM
fabworxs's Avatar
Default Re: (Subwarrior)
steddy light is bad ecu if i'm correct.
Old Jan 2, 2005 | 06:29 PM
Subwarrior's Avatar
Default Re: (fabworxs)
Enigine lights don't blink. They are steady until you make the connection to make it blink the trouble codes. This is what I am trying to figure out. If you have a trouble code, the light isn't going to blink that code number all the time just because there's a code. The engine light is on when a code exists, I need to make it blink to figure out what the codes are.
Old Jan 2, 2005 | 08:16 PM
duofilm's Avatar
http://www.c-speedracing.com/faq/06.php
Try reading this. If you don't know how to pull the codes than I think this will help you.
Old Jan 4, 2005 | 07:30 AM
Subwarrior's Avatar
Default Re: (duofilm)
I already knew the wire jump trick and counting codes. What I couldn't find was where the connector was located, and the wire colors etc. That was the info I was looking for, thanks much.
Old Jan 4, 2005 | 07:51 AM
v4lu3s's Avatar
RTFM
the 2 wire jumper is right next to teh obd2 scan port. its nt eh blue plug right there.
Old Jan 12, 2005 | 06:35 PM
Subwarrior's Avatar
Thats what I thought. I looked behind the kick panel on pass side and didnt see the one the other post said. The blue wire I have found, but the CEL doesnt do anything when I jump them.
jdm-hondacura
Oct 18, 2006 02:06 PM
rhemu1
Aug 6, 2004 08:09 AM
type Gendy
Apr 21, 2003 04:48 PM
Jago
Dec 28, 2002 05:11 AM
