EG oem sway bar diameter
Old Dec 31, 2004 | 07:08 PM
jdmbb6's Avatar
Default EG oem sway bar diameter
what's the oem 92-95 eg si diameter? i'm looking at a jdm one which is 20 or 21mm so i wanna know if it's worth it to buy the jdm one
Old Dec 31, 2004 | 08:17 PM
Street Ghost's Avatar
Default Re: EG oem sway bar diameter (jdmbb6)
Front Sway: 22mm
Rear Sway: I don't think they came with one, but if they did, it's probably 13mm or 14mm (I think..)
BTW, if you go with a thicker rear sway bar, it's recommended that you reinforce your subframe to prevent tearing it.
Old Jan 1, 2005 | 04:43 PM
jdmbb6's Avatar
Default Re: EG oem sway bar diameter (_Edge.ONE)
so then the oem and jdm are the same diameter then?
Old Jan 1, 2005 | 04:57 PM
gt30typer's Avatar
I would go with an LS or GSR sway bar they are cheap and the same size as an ITR.
raleylund
Suspension & Brakes
15
Oct 18, 2010 09:33 PM
rtuner
Suspension & Brakes
24
Aug 2, 2009 08:33 PM
Paul-eg
Aug 29, 2008 04:33 PM
b20acura
Oct 2, 2006 12:17 PM
