Will a 92 Integra reardisc fit on 92-95 civic hatch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18ek »</TD></TR><TR><TD CLASS="quote">Anyone know if the complete front and rear disc setup from a 92 integra fit on a 92-95 civic DX hatch? Bolt on? thanks</TD></TR></TABLE>
Search. Search search search. This has been covered so many times, you should be shot for even thinking to start a new thread about it.
Rear discs are a direct bolt-on. You can either swap the hub assemblies onto your existing trailing arms, or swap the entire trailing arm - just keep in mind that the '90-93 Integra trailing arms use a slightly larger bushing than others, and you'll need to use your stock compensator arms.
As far as the fronts go, I'm not sure if the '90-93 Integra knuckles have the proper geometry or not. Try a search. '94-01 Integra knuckles are a direct swap though and would allow you to use the larger 10.3" brakes; Civic EX knuckles will also work with 10.3" brakes.
What are the compensater arms? Be more specific? The upper arm? And you don't gotta talk ****. Its unnecessary, really. Just trying to get advice.
but thanks for the info....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18ek »</TD></TR><TR><TD CLASS="quote">What are the compensater arms? Be more specific? The upper arm? And you don't gotta talk ****. Its unnecessary, really. Just trying to get advice.
but thanks for the info....</TD></TR></TABLE>
No. Targa is absolutely right. There is ABSOLUTELY no reason that someone should start a new thread asking the most general question about integra brakes. You need to search.
nekoabandoned
Aug 17, 2007 01:15 AM
See Are X
Jun 5, 2006 07:16 AM
dem0nk1d
Mar 16, 2006 11:45 AM
