Idea I had for anti-tow truck theft...
Old Dec 31, 2004 | 02:14 PM
AngelTeg's Avatar
Default Idea I had for anti-tow truck theft...
Bear with me, I was thinking about this and wanted to see if anybody else thought it made sense...
I was reading a tow truck theft thread on here, and an owner of a tow-truck said that no matter what, his winch was strong enough to drag a car even if the wheels couldn't spin.
That got me thinking, what if there was a way to park your car, and leave it in neutral so that the wheels could spin...
Because think about it this way... if your wheels were free to move, and you cut your steering wheel all the way to one side, if a tow-truck tried to pull your car, instead of dragging it, the car would actually roll off to the side, and hit another car (or two)
I hope you guys understand what I'm talking about, I know I didn't explain it well.
-Mike
Old Dec 31, 2004 | 02:16 PM
rgaray's Avatar
I think he can still put it in gear from underneath the car.
Old Dec 31, 2004 | 02:28 PM
thaiphob's Avatar
Nikon!!!
Default Re: (rgaray)
if some theif has access to a tow truck, there is no hope for your car. its gonna be stolen. remember only the most commited will win.
Old Dec 31, 2004 | 02:35 PM
LSvtec03's Avatar
Default Re: (thaiphob)
well, if your car is a manual, you can park it in neutral. the problem is that if a truck can pull any car with the wheels locked, then it's still capable of pulling a car whether it's pointed in that direction or not.
Old Dec 31, 2004 | 02:40 PM
tegUNO's Avatar
Default Re: (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">well, if your car is a manual, you can park it in neutral. the problem is that if a truck can pull any car with the wheels locked, then it's still capable of pulling a car whether it's pointed in that direction or not.</TD></TR></TABLE>
Yeah, what he said
Old Dec 31, 2004 | 03:09 PM
MassScene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">well, if your car is a manual, you can park it in neutral. the problem is that if a truck can pull any car with the wheels locked, then it's still capable of pulling a car whether it's pointed in that direction or not.</TD></TR></TABLE> but how would he keep the car going strait?
Old Dec 31, 2004 | 03:10 PM
MassScene's Avatar
Default Re: (MassScene)
but anyway there is other ways around that. there are these dollies you put around your wheels and by stepping on a lever they raise up and actually keep your wheels of the ground..... shops use them for moving cars around the shop.
Old Dec 31, 2004 | 04:31 PM
gtfour43's Avatar
A tow truck can take it no matter what. Even if you turn your front wheels all the way to one side he can still take it. Since its fwd they'll most likely try to grab it from the front to not damage the trans and then he has to deal with the parking brake and he'll either slim jim the lock and release the brake himself or just use his dollys and tow it on that.Your best bet is to get your wheels as close to the curb or anything else solid so his claws or dollys cant get around them to pick them up. Sometimes if I park near a pole or something i'll get as close as I can then turn the wheels so that the car cant be dragged out of the stall without removing the pole or without turning the front wheels. There's ways to slow the process but in the end if the truck driver needs to tow it.............its gone.
Old Dec 31, 2004 | 05:46 PM
orion840's Avatar
Default Re: (gtfour43)
if they wanna take it
they will it sucks
Old Dec 31, 2004 | 05:52 PM
tegsallgood's Avatar
Default Re: (orion840)
have a hook cemented into your driveway-parking space- and chain the frame to the ground with some heavy duty chains.
Old Dec 31, 2004 | 05:59 PM
DA9RsIntegra's Avatar
Default Re: (tegsallgood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegsallgood &raquo;</TD></TR><TR><TD CLASS="quote">have a hook cemented into your driveway-parking space- and chain the frame to the ground with some heavy duty chains.</TD></TR></TABLE>
I've always thought of this.. Maybe I'll do it whenever I hit the ITR realm/ Till then, my busted *** RS is fending for itself, well kinda
Old Dec 31, 2004 | 06:02 PM
b-power's Avatar
Default Re: Idea I had for anti-tow truck theft... (AngelTeg)
you can be parked parallel to the curb with a car behind and in front of you and they still got ways of getting your car.
Old Dec 31, 2004 | 06:15 PM
AngelTeg's Avatar
Default Re: Idea I had for anti-tow truck theft... (b-power)
nah, well what I'm saying is taht if the wheels are cut all the way to one side, then if they try to pull it, it will just roll into the car parked next to it... get it?
-Mike
Old Dec 31, 2004 | 06:52 PM
Code Blue's Avatar
95 percent of the flatbed tow trucks also has a grabber attached to the back, which means, the guy doesn't even have to get out of his truck, he backs up in front of you, and then the grabbers drop to the ground, go around your front wheels, around and then lift up.
if they want to take your car, they can take it
Old Jan 1, 2005 | 04:52 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AngelTeg &raquo;</TD></TR><TR><TD CLASS="quote">nah, well what I'm saying is taht if the wheels are cut all the way to one side, then if they try to pull it, it will just roll into the car parked next to it... get it?
-Mike</TD></TR></TABLE>
but if a truck can pull a car with the wheels locked and brake on, it will just squeal all the tires and pull it forward. just cuz the wheels are cut to the side doesnt mean that's the only way it will go. the truck will pull the car against the way the wheels are turned.
Old Jan 1, 2005 | 05:02 PM
AngelTeg's Avatar
Default Re: Idea I had for anti-tow truck theft... (LSvtec03)
ya, but i'm saying the wheels arent locked, so when they pull it, the car will move freely 9which they may or may not be expecting) and when they try pulling it, it will roll (freely) into another vehicle.
either way, seems like it's not a good idea, not alot of positive feedback...
-Mike
Old Jan 1, 2005 | 05:52 PM
njandrewg's Avatar
they can always use a flat bed.
Old Jan 1, 2005 | 06:12 PM
TrueUntilDeath.com's Avatar
Default Re: Idea I had for anti-tow truck theft... (njandrewg)
thats what i do, it will slow down the theif, but eventually, they will still get away with your car.
garage your car when you are at home, and dont take your car when you go to the movies or to the mall where you would leave your car outside for 3-4 hours. carpool
R Legend
Nov 19, 2005 05:34 PM
civicdragger818
19
May 2, 2003 01:02 PM
fire7882
16
Mar 25, 2002 03:56 PM
jamal-188
Audio / Security / Video
Feb 21, 2002 06:55 PM
johng
Jul 13, 2001 09:53 PM
