no spark
Old Dec 31, 2004 | 02:09 PM
jax8686's Avatar
Default no spark
i finally got my car going again after doing a major overhaul of the top end... it ran for a minute or two, nicely, then suddenly died... i have no spark.. any ideas?
Old Dec 31, 2004 | 04:30 PM
b16h22a's Avatar
start by making sure no connections came loose then chech the fuses
Old Jan 1, 2005 | 05:38 AM
dirtracer's Avatar
Default Re: no spark (jax8686)
check the timeing belt. Just had that problem it must be catching.....
Old Jan 1, 2005 | 12:28 PM
jax8686's Avatar
Default Re: no spark (dirtracer)
everything in the top end is working good, ive heard distributors are kinda poor on accords.... i have power goign to the distributor, but no spark comin out the other side... all my fuses are good... gotta love new years tho, no where open to get parts
Old Jan 1, 2005 | 04:42 PM
jdmcb3's Avatar
check the ignitor or coil for power
Old Jan 3, 2005 | 12:45 PM
jax8686's Avatar
Default Re: no spark (jdmcb3)
i put a new ignitor, and i have a new coil in a bag, but i dont want to open it yet cuz of return policies.. anyone know all the tests for an internal coil?
Old Jan 5, 2005 | 08:53 PM
Accordinglynice's Avatar
I had that problem. Check if ur timming aint jump. Take the cap out crank the car if the rotor spins the timming belt is good. Check your cap rotor wires also. Or take the gas line out crank the car gas shoots up ur main relay is good. If not it can be your main relay also hondas r know for the main relays aways going
Old Jan 6, 2005 | 07:42 AM
BLACK_DEL_SOL's Avatar
Default Re: no spark (Accordinglynice)
had the same problem turned out it was my dizzy, i had replaced the wires,dizzy cap,and everything in between .
Old Jan 6, 2005 | 04:37 PM
honda accord's Avatar
definite...igniter.....if it turns over and wont start ...igniter
Old Jan 6, 2005 | 06:35 PM
PrettyLude's Avatar
ignitor
Old Feb 7, 2005 | 09:01 PM
usfsfirefighter0's Avatar
Is the wireharness arcing on the motor at all there maybe short? If not the distributor it could also be the computer try put a your ecu in a friends car with similiar swap, u can try to putt another ecu in yur car, or u can also do this with distributor. Also check check ign fuse (15 amp) in the fuse box in the dash and the engine bay ? Hopefully this works or steers u to the problem but if u find the problem please let me know ok?
Old Feb 7, 2005 | 10:04 PM
rival12's Avatar
no spark, so doesn't turn over?? i would say ignition coil same thing happened to me, we routed up an external coil for a bit, then we replaced the internal coil
dullboy01
Nov 20, 2009 12:44 PM
S2KILLA
Nov 29, 2006 06:00 AM
rdssk8rcs1
Jun 5, 2006 04:13 PM
moon1961
May 30, 2004 11:34 AM
crxzc
Jun 9, 2002 06:50 PM
