"3-channel amp"
Old Dec 31, 2004 | 01:38 PM
b16sellout's Avatar
Default "3-channel amp"
Know enough about electronics/stereos to wire up my system, but I'm curious to whether there are any adverse effects of using my 4-channel amp to drive my 6x9's (one channel each) and then bridge the other two channels to run my sub on. Adverse effects such as noise on the lines somehow, or if it might hurt my amp, and if this is even possible to do. Thanks
Old Jan 1, 2005 | 09:50 AM
fcm's Avatar
fcm
Old Fart
Default Re: "3-channel amp" (b16sellout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16sellout &raquo;</TD></TR><TR><TD CLASS="quote">Know enough about electronics/stereos to wire up my system, but I'm curious to whether there are any adverse effects of using my 4-channel amp to drive my 6x9's (one channel each) and then bridge the other two channels to run my sub on. Adverse effects such as noise on the lines somehow, or if it might hurt my amp, and if this is even possible to do. Thanks</TD></TR></TABLE> Its no problem, as long as the load on the two ch. that you bridge sees a load of no less then 4OHMs, also I would amp the front speakers, not the rears, and if the amp has a x-over run the fronts highpass, use the HU power to run the rear speakers, and if they have tweets, disable them. 94
Old Jan 1, 2005 | 05:50 PM
b16sellout's Avatar
Default Re: "3-channel amp" (fcm)
Is that going to give me a better sound to amp my 6 1/2" door speakers instead of the 6"x9" rears?
Old Jan 2, 2005 | 05:20 PM
Vanilla Sky's Avatar
gernerally speaking, yes... you don't want to hear more sound from behind you than you do from the front...
imagine being at a concert and the speakers were behind you while you are facing the stage... now imagine that the speakers are up front... which would sound better?
and no, it shouldn't hurt the amp to run it as 3 channels, as long as it was designed to run as such
pityocamptes
Audio / Security / Video
Dec 4, 2017 03:01 AM
93vtec ATL
Nov 4, 2005 11:36 AM
Orpheus1985
Jul 31, 2005 04:11 PM
AznImage504
Aug 30, 2004 06:00 PM
shyboy817
Aug 12, 2004 11:30 PM
