Power Steering Belt Removal 1991 Prelude
Old Dec 31, 2004 | 01:14 PM
breezer69's Avatar
Default Power Steering Belt Removal 1991 Prelude
I have a 1991 Prelude and I can not figure out how to get the power stearing belt off. A major problem when you have to replace the power steering pump. Does the tensioner that you can not get too have an adjustment bolt somewhere? Thanks for any help.
Breezer
Old Dec 31, 2004 | 02:25 PM
Prolink's Avatar
Default Re: Power Steering Belt Removal 1991 Prelude (breezer69)
1- loosen the 14mm tensioner pulley bolt
2-lossen the 2 14mm or 12mm bolts on powersteering pump
3-undo the 10mm tensioner adjust bolt
Old Dec 31, 2004 | 02:32 PM
breezer69's Avatar
Default Re: Power Steering Belt Removal 1991 Prelude (Prolink)
Thanks for the info but where is this 14 mm tensioner bolt located. I cannot find anything that looks like it will loosen it? Thanks for your help.
Breezer.
jarred1414
Nov 14, 2014 10:27 AM
penultimeta
May 23, 2010 03:31 PM
TMC_EF
Jul 19, 2007 07:58 PM
prelude964
Aug 8, 2005 11:51 AM
