how are the top of the cylinders supposed to look?
i pulled the spark plugs and when i looked inside the top of the cylinders are very grimy like built up oil. motor has almost 2k on it. is it supposed to look like that?
yeah that's all the carbon build up, when the gas and air combust, it leaves carbon residue, and if you run that shitty *** arco gas it will do the same, all you need to do is run shell v power, and some gas treatment in your gas tank and that **** will clean it up and make your car run better, also if you use cheap *** oil, will do it too I only run mobile 1 oil it's race prov en, and it's what the use in formula one racing. it's the best
i dont know if mines looks like that, it looks shiny and wet looking, maybe because the motor is still all intact, i just looked through the spark plug hole, bump for anything other ideas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One »</TD></TR><TR><TD CLASS="quote">Here's a D16Z6 with 130k on it...no FI and stock ecu....
</TD></TR></TABLE> This Z6 could of used some seafoam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95sihb »</TD></TR><TR><TD CLASS="quote"> This Z6 could of used some seafoam</TD></TR></TABLE>
hey!...it raise the compression .001 points!
