Ball joint boots leaking grease...
Old Dec 31, 2004 | 11:07 AM
cdog19's Avatar
Default Ball joint boots leaking grease...
I made a post how I am having trouble with my spring install, well during the process I have been disconnecting ball joints and as a consequence I have cut open the lower ball joint boot, as well as the one for the steering arm, not that much grease came out but I dont have the boots to replace and refill them with grease. How big of a problem is this? And I am eager to finish this spring install but how long can these be driven on before properly replaced and refilled with grease?
EDIT: On an EP3
Old Dec 31, 2004 | 11:40 AM
msmotorsports's Avatar
Default Re: Ball joint boots leaking grease... (cdog19)
Once the grease is gone you will get metal to metal contact which will wear the joint down. I would suggest replacing the boots and filling with synthetics joint grease. You won't see any damage while driving with damaged boots but long term effects will not be worth it.
Old Dec 31, 2004 | 11:42 AM
cdog19's Avatar
Default Re: Ball joint boots leaking grease... (msmotorsports)
Ok, well I guess I will have to replace them when I get back into town then...
unclematt
Jun 2, 2016 06:11 PM
beanbag
Transmission & Drivetrain
Apr 28, 2014 08:34 PM
Master23
Jun 23, 2009 03:18 PM
teawoboba
Jun 16, 2004 09:58 AM
Aron Parsons
Aug 1, 2002 05:22 PM
