turbo f22b2
i'm looking at building my f22 instead of doing the h22 or h23 swap. now i can either get a full kit and spend a few grand and get it all or do a junkyard pieced together turbo. just wondering if anyones had experience with this and what to look out for or expect as problems etc.
i say go junkyard turbo , i went turbo on my del sol everything was from the junk yard i spent $50 for a t3 turbo , smic free and free misc hoses and pipes ,went with a cheapo bosch bov $15 ,copper feed line 4 feet 8 cents, rubber return line free junk yard ,fmu $30 ,fuel reg $10 and a cheapo apc crap boost guage $10
total 115.08 ran the del sol with 9 psi of boost on regular gas and that **** ran nice , until the seals on the turbo began to leak like a month later
and a month after that blew a head gasket
but hey what do you expect from a car with 180k miles and running a t3 turbo at 9 psi of boost with no waste gate
^ ummm how were you running 9psi with no wastegate? without a wastegate you would just keep building boost till you blew your **** up or destroyed the turbo (seems like you did both)
I advice against a junkyard set-up, if you want a pos set-up go for it, otherwise piece a kit together yourself using decent parts. no FMU, get real management.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord387 »</TD></TR><TR><TD CLASS="quote">^ ummm how were you running 9psi with no wastegate? without a wastegate you would just keep building boost till you blew your **** up or destroyed the turbo (seems like you did both)
I advice against a junkyard set-up, if you want a pos set-up go for it, otherwise piece a kit together yourself using decent parts. no FMU, get real management.</TD></TR></TABLE>
TRUTH!!!
TRUTH!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeIsCool »</TD></TR><TR><TD CLASS="quote">junkyard
talk to Accord94dx he had an f22b2 turbo accord my friend owned for a few months. it make like 180 tq and 155 hp with a t25 and 4lbs.</TD></TR></TABLE>
That car was not a junkyard kit!!!!
It was the only Accord in the states sportin the HKS turbo kit.
talk to Accord94dx he had an f22b2 turbo accord my friend owned for a few months. it make like 180 tq and 155 hp with a t25 and 4lbs.</TD></TR></TABLE>That car was not a junkyard kit!!!!
i just finalized my turbo setup on my 97 f22b2.
heres what i have
custom fabbed manifold, downpipe, exhaust, IC piping, and oil lines
Johnny race car front mount
walbro 255lph fuel pump
garrett t25 (stock 2g eclipse turbo)
1g dsm BOV
dsm 450 cc blue top injectors
autometer boost, EGT, and oil pressure guages
(ordering an AEM FPR tomorrow)
running uberdata with a p06 ecu and JDM **** OBD1 conversion harness
PLX m300 wideband.
I am having some fuel troubles right now. my fuel pressure is way too high so my car was running pig rich at idle (10:1 AFR) and those 450's were dumping way too much fuel in. so i put my stock obd2 ecu and stock injectors back in and disconnected the wastegate actuator arm from the flapper so it wouldn't make any boost and drove it home.
tonight i started having some fuel issues with fuel spewing out the injector seals cause the pressure is too high. so im hoping the FPR will fix the problem.
If all goes well i should have it tuned in the next week and i will post my results along with some pictures of the setup.
heres what i have
1g dsm BOV
PLX m300 wideband.
It's all about what manifold is available for cheap and a turbo that fits the manifold. Cheapest way to do it is to get a manifold off a stock car wiht the turob that came with it so you don't have to worry about finding a turbo with the same flange.
If you can get those things...everything else is fairly cheap and can be customized easily. Only other part would be having to get a cutom downpipe made to connect to your exhaust.
I had a 240sx stock engine that I build a turbo kit using DSM turbo. It ran great while i had it. Engine had a lot of miles on it so the engine eventually messed up the rings but with accords, many have been runing mild boost levels with no problem (4-8psi) so I don't think you have to worry about it.
If you want cheap, then go junkyard setup. If you want guaranteed fit and all your parts at once, buy the kit. It's all about how much effort/time you can put into it. It took me about 3 months to scrounge all the pieces I needed for my junkyard setup.
dang i suck legendaryyaj. I seriously have been so off on HT lately. Mike told me that like 345445 times that it was the only hks kit in the states. Thanks for correcting me,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeIsCool »</TD></TR><TR><TD CLASS="quote">dang i suck legendaryyaj. I seriously have been so off on HT lately. Mike told me that like 345445 times that it was the only hks kit in the states. Thanks for correcting me,</TD></TR></TABLE>
Your quote made it seem as if his kit was a junkyard kit.
so you telling me that doesnt make someone who didnt know think that the car was made with a junkyard kit.
You stated nothing about the HKS kit and made it seem as if the kit was made from a junkyard kit.
</TD></TR></TABLE>so you telling me that doesnt make someone who didnt know think that the car was made with a junkyard kit.
I wasnt being sarcastic when I said thanks for correcting me. 94accorddx's old accord had the only accord hks kit in the states. I think junkyard kits can be more customized and cheaper. Finding all the parts and getting them to work in harmony is the challenge.
My "Junkyard" kit so far - not done....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
F22B2 Longblock - bought used with 60k on it $690
Autometer A/F ratio gauge 50
Eagle H22 rods 310
Acid Bath (to clean block) 30
Drag gen IV turbo manifold 300
Helm's Accord manual 70
Custom CP Pistons 500
Bore and Hone block 65
ACL Bearings 105
ARP H23 Head Studs 116
EFI 101 class 350
Action 1MS Clutch 320
B&M Fuel Pressure Regulator 70
Fuel Pressure Gauge 45
Zeitronx Wideband O2 290
Willem EEPROM Burner 45
Autometer Oil pressure gauge 54
Autometer Boost gauge 55
Energy Suspension motor mount inserts 17
Firewall Oil Supply Distribution Line Kit 25
Remanufactured flywheel 45
Intercooler + shipping 280
Used T3/T04E + shipping 280
Intercooler piping 100
UberData / Crome / P05 ECU Free
Various silicone connecters 100
Various AN Fittings 50
K&N Filter 40
Precision 580cc Injectors (used) 225
KTeller 2.5 Exhaust 223
Forbidden Motorsports Shortshifter 125
Various Gaskets for engine 150
Running Total: $5125
whoops, add $400 for the Tial Wastegate and BOV and 30 for Vacuum manifold!
And btw, this doesn't include any fabbing/welding labor as I'm doing it all myself (I have a welder)
Eagle H22 rods 310
ACL Bearings 105
EFI 101 class 350
K&N Filter 40
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlove »</TD></TR><TR><TD CLASS="quote">That car was not a junkyard kit!!!!
wrong</TD></TR></TABLE>
thanks tips you missed it by 2 days...legendaryyaj already corrected me
$400 for BOTH WG and BOV (package deal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22b2tdave »</TD></TR><TR><TD CLASS="quote">yikes! tell me you did NOT pay 400 bucks for a tial, i got mine brand new for 225...are you running the 35mm or bigger?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legendaryyaj »</TD></TR><TR><TD CLASS="quote">
You stated nothing about the HKS kit and made it seem as if the kit was made from a junkyard kit.</TD></TR></TABLE>
Damn dude, pull the stick outta your ***. He was saying YOU are right and HE was wrong. Its not like he made a mistake about your car either. You're all worked up over someone else's ride
So its got an HKS kit, whoopty-*******-do. No one is impressed.
Its pretty insignificant and you shouldn't get all worked up because he made a simple mistake. At least he admitted it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMAccord2nr »</TD></TR><TR><TD CLASS="quote">
So.......you saying by him posting this:
Someones not trying to be a smartass? Either way I got the point so you pull the stick outta ur *** for being all late.
Like you said, no one's impressed so why are you posting your post to get the stick outta my ***?!?!
/arguement
</TD></TR></TABLE>So.......you saying by him posting this:
</TD></TR></TABLE>Someones not trying to be a smartass? Either way I got the point so you pull the stick outta ur *** for being all late.
/arguement
His original quote was obviously not sarcastic. He acknowledges he was wrong and thanked you for showing him his error. He even made a separate post to say he wasn't being sarcastic. Seems like you could be a little more polite then continue to harass him about a mistake. For Christ's sake, its not your car!!!!!!! You're acting like he fucked your mom
