Crazy Idle... Techs Please Help
Old Jan 7, 2002 | 01:22 PM
BeanRacer's Avatar
New User
Default Crazy Idle... Techs Please Help
While driving, when I pull up to a stop to slow down, I throw the car in neutral and my idle seems to rev like 2500 RPM. When the car comes to a complete stop while in neutral, it still revs high at 2500 Rpm. Sometimes when I'm lucky, I'll get a 900 RPM idle. I have spec B's and i lean out the gas with the Field unit to -4% at 1000 Rpm.
Any advice?
Old Jan 7, 2002 | 01:24 PM
junglistgsr's Avatar
Default Re: Crazy Idle... Techs Please Help (BeanRacer)
could be the fast idle valve....or maybe your throttle cable sticks? do the revs ever go up and down when its warming up?
Old Jan 7, 2002 | 01:29 PM
BeanRacer's Avatar
New User
Default Re: Crazy Idle... Techs Please Help (junglistgsr)
MY idle goes down when I'm warming up the car and usually stalls but that is natural with Spec Bs. I have to lean out the gas about -15-20% at 1000 Rpm when starting the car.
Old Jan 7, 2002 | 01:31 PM
Black R's Avatar
25 Year Member
You have to do that all the time with the B's... Not just on startup. Also, try turning the throttle screw clockwise a turn or so and let us know how that fares. Should lower your idle. Only do this when the car is warm though, otherwise it'll change as the car warms up.
Old Jan 7, 2002 | 02:24 PM
98TypeR's Avatar
Default Re: Crazy Idle... Techs Please Help (Black R)
it should be lower than -4%. mine was at -25%. maybe get your car tuned on the dyno/
Old Jan 8, 2002 | 10:03 AM
Black R's Avatar
25 Year Member
Default Re: Crazy Idle... Techs Please Help (98TypeR)
Yeah, at idle I had to play with it from -25% to -35% at 1000 on the part throttle settings to get a decent idle. Anything richer and it would kill itself after a few minutes...
Old Jan 10, 2002 | 08:08 AM
Black R's Avatar
25 Year Member
.....hey bean, your IM comes through to me blank. Weird. Just post up here and we'll continue. Sorry, but I can't read your h-t IM's...
Old Jan 10, 2002 | 08:19 AM
BeanRacer's Avatar
New User
My idle read 700rpm now and sometimes fluctuates to 1000rpm and thats on the Field's Tach.
Old Jan 10, 2002 | 08:22 AM
Black R's Avatar
25 Year Member
...ok, it should read 800 +/- 50 rpms... 700 is kinda low if it stays there... Mine would dip occasionally, but with playing on the throttle screw and leaning it out at 1k rpms at part throttle settings helped. I'd say play with that throttle screw a little more, maybe 1/2 turn clockwise again or 1 turn ccwise...
Old Jan 10, 2002 | 08:56 AM
ak-s2000's Avatar
Is this true? With the Spec B cams the car will stall until warmed up. I find this hard to believe, otherwise no one would use them. Sounds like a tuning problem.
Old Jan 10, 2002 | 02:29 PM
BeanRacer's Avatar
New User
Default Re: Crazy Idle... Techs Please Help (ITR_0207)
It happens to me alot cause my car is not tuned but also the weather drops to like 20 degrees. Thats when I have to lean out the gas. Then after a couple of minutes the car idles fine.
josh devera
Jan 9, 2018 04:38 AM
bdubnyc
11
Apr 18, 2008 09:39 PM
Bizarre
Sep 6, 2007 09:40 AM
FeRioR$
Nov 30, 2004 08:45 PM
MeanGreenEG9
Mar 6, 2003 09:19 PM
