My FAULT or BAD TRANNY??
Old Dec 31, 2004 | 09:07 AM
HmgLauj69's Avatar
Default My FAULT or BAD TRANNY??
okay i thought all gear oil where the same, anyways bought two quarts of valvoline 85w 140 gear oil. installed my tranny and 2nd gears like a mother, the tranny had no gear oil at all before i add the 2 quarts of the 85w 140...so i started searching and im suppose to use 10w 30 motor oil/Honda MTF or gm synchromesh .....my question is that is the cause of the grind most like the 85w 140? and how many qarts do you put in a b-series tranny after complete drain?? help me out guys
Old Dec 31, 2004 | 09:25 AM
nickG's Avatar
Default Re: My FAULT or BAD TRANNY?? (HmgLauj69)
i have no idea what you use 85w-140 for..what did it say on the package??? just "car gear oil??"
but youre suposed to use manual tranny fluid like the honda mtf or gm stuff ive read are both good and regular motor oil in an emergency..
it sounds to me like you installed a new tranny, with this weird oil, and now it grinds..if you dont know if it grinded before than you really cant know if it is the tranny or the oil..
Old Dec 31, 2004 | 09:37 AM
purplegsr's Avatar
85w-140 is a super heavy duty gear oil, it is usually used in light commercial trucks and vans. It is quite a bit thicker than 10w-30 oil, usually 75w90 gear oil is close to a 15w-40 engine oil, so 85w-140 is even thicker. This gear oil could very well be the cause of the grinds (synchros won't operate well if the oil is too thick), but it should go away once you swap in some Honda MTF, 10w30, or another lighter weight oil (redline, syncromesh, etc). I doubt you did any permanent damage as long as you haven't been driving much.
The complete overhaul of a tranny usually takes 2.3 qts of fluid.
Old Dec 31, 2004 | 09:53 AM
HmgLauj69's Avatar
Default Re: My FAULT or BAD TRANNY?? (purplegsr (Exospeed))
good ****, how do you do a complete tranny flush anyways i dont think i cant get all of it out with the autozone gear oil hand pump
Old Dec 31, 2004 | 09:58 AM
purplegsr's Avatar
I would just buy double the amount you need (~5 qts), drain and fill it once, drive around for 5 minutes, shift through all of the gears, and see if the grinds got better. Then go back, drain it one more time and refill again. If you want to use Syncromesh, the Pennzoil Syncromesh you can find at AutoZone is the same as the GM version (and much cheaper), you won't feel as bad draining it after 10 miles.
Old Dec 31, 2004 | 10:40 AM
b16h22a's Avatar
just drain and refill with the proper fluid the fact that the transmissionhad no fluid before couldent have helped the fact
Old Dec 31, 2004 | 02:56 PM
HmgLauj69's Avatar
well i drained it and replaced it with honda mtf and it still grinds...god damn, damn seller lied to me and ****....i bought it thinking it was in good condition now he wont even reply my emails....i'll drive it for a while and give you guys an update later, i heard it could be a while before it stops grinding
Old Dec 31, 2004 | 03:07 PM
MassScene's Avatar
GM SYNCROMESH!!!! It works wonders i tell ya. Make sure you ask for the "GM syncromesh-friction modified". Thats the goooood ****.
Old Dec 31, 2004 | 05:19 PM
HmgLauj69's Avatar
Default Re: My FAULT or BAD TRANNY?? (MassScene)
i'll try that next but wouldn't only hide the problem? i'll have to rebuilt my tranny no matter right? usdm itr tranny by the way
mattbatson
Apr 8, 2012 04:28 PM
rEnZ94tEgGy
Jul 20, 2008 12:30 PM
Aespooncivic
29
Apr 1, 2005 12:14 PM
RACINTWEEK
Dec 13, 2004 09:31 AM
overdose
Jun 24, 2003 04:33 PM
