1999 b16 o2 sensor QUESTION
Old Dec 31, 2004 | 01:04 AM
teamm_AP1's Avatar
Default 1999 b16 o2 sensor QUESTION
i'm swapping a 1999 b16a2 in my 1999 hatch. I'm aware that there are two 02 sensors; one goes to the header & cat.
I already have a aftermarket header and it has a 02 sensor plug but i'll need another placement for the other 02 sensor.
My questions are.. what are my options?
1. Get a 1999 Si cat
2. Aftermarket cat?
Is there any other way to do this? because i don't want the engine to run rich & check engine light on.
Any help will be appreciated. Thanks!! OH AND HAPPY NEW YEAR!!
Old Dec 31, 2004 | 01:37 AM
teamm_AP1's Avatar
Default Re: 1999 b16 o2 sensor QUESTION (MiSCHiEF_EK)
bump
Old Dec 31, 2004 | 06:35 AM
Boston_George's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiSCHiEF_EK &raquo;</TD></TR><TR><TD CLASS="quote">i'm swapping a 1999 b16a2 in my 1999 hatch. I'm aware that there are two 02 sensors; one goes to the header & cat.
2. Aftermarket cat?
Any help will be appreciated. Thanks!! OH AND HAPPY NEW YEAR!!</TD></TR></TABLE>
Hey what's up... This is a common problem with these swaps...
Okay first you MUST run the first o2 sensor that bolts into the header. You car will run fine with the first o2 sensor there and missing the second, but you'll have the check engine light on (it will be throwing a "problem 2nd o2 sensor" cel). If you have an aftermaket full exhaust system (like RSR, greddy, etc.) you don't need the cat... The exhaust and header bolt up perfectly (only on ek's)..... Now you need to get rid of the check engine light (if you want to). To do this, you can by an o2 simulator (O2SIM) made by ziptech. It's like $50.00 and it will trick the ecu to think that your getting a valid secondary o2 signal, and you check engine light will be gone... I hope this helps. Oh you if you want to wire in the secondary o2 sensor... It can be done... You'll need to run four new secondary o2 sensor wires to the ecu.
Old Jan 1, 2005 | 05:14 PM
teamm_AP1's Avatar
Default Re: 1999 b16 o2 sensor QUESTION (JRSCB16ARipster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRSCB16ARipster &raquo;</TD></TR><TR><TD CLASS="quote">Hey what's up... This is a common problem with these swaps...
Okay first you MUST run the first o2 sensor that bolts into the header. You car will run fine with the first o2 sensor there and missing the second, but you'll have the check engine light on (it will be throwing a "problem 2nd o2 sensor" cel). If you have an aftermaket full exhaust system (like RSR, greddy, etc.) you don't need the cat... The exhaust and header bolt up perfectly (only on ek's)..... Now you need to get rid of the check engine light (if you want to). To do this, you can by an o2 simulator (O2SIM) made by ziptech. It's like $50.00 and it will trick the ecu to think that your getting a valid secondary o2 signal, and you check engine light will be gone... I hope this helps. Oh you if you want to wire in the secondary o2 sensor... It can be done... You'll need to run four new secondary o2 sensor wires to the ecu.</TD></TR></TABLE>
I forgot to mention that I'm also using the b16a2 ECU. Would I still need to wire 4 wires to the ECU?
About the Ziptech 02 simulater (02SIM), will that hurt the engine in any way?
Old Jan 1, 2005 | 08:42 PM
teamm_AP1's Avatar
bump
Old Jan 1, 2005 | 08:46 PM
Kamin's Avatar
Default Re: (MiSCHiEF_EK)
the only thing the second o2 sensor does is monitor catalytic converter efficency, no you will not hurt the engine.
Old Jan 2, 2005 | 12:57 AM
teamm_AP1's Avatar
Default Re: (Kamin)
OK cool, that is good to know.
also, would i still need to add 4 wires to the ECU for the secondary 02 if i use my stock wiring harness & a 1999 si ECU? Because I do have two stock 02 sensors since my car is a 99'.
Modified by MiSCHiEF_EK at 6:54 AM 1/2/2005
Old Jan 2, 2005 | 05:55 AM
teamm_AP1's Avatar
Where can I find the 02SIM thats made by ZIPTECH. I searched but couldn't find anything.
Jacob Giannini
Honda Civic (2001 - 2005)
Jan 10, 2019 02:04 PM
Damon Reeves
Oct 10, 2006 01:39 PM
BLUE EH3
14
Jun 19, 2005 10:16 PM
solkid
Apr 9, 2002 09:33 AM
