How did you make the slash cut on the feedback air tube from the valve cover?
Old Jan 7, 2002 | 12:46 PM
citanest's Avatar
New User
Default How did you make the slash cut on the feedback air tube from the valve cover?
Hi, I want to know how some of you make the slash on the the tube that feed back to the intake hose from the valve cover? I was try to use a strew, but didn't work. I am afriad that the strew will get loose and suck into the manifold. Anyone?
Old Jan 7, 2002 | 01:10 PM
sgT's Avatar
sgT
Default Re: How did you make the slash cut on the feedback air tube from the valve cover? (citanest)
i didnt.
Old Jan 7, 2002 | 01:26 PM
Warren's Avatar
Wrong-Way Wang
You don't really need it, but for reference, you can buy thin metal tubing for these sorts of projects from hobby shops. Cut the tube with the smallest pipe cutter you can find. If you need to cut at an angle, use a fine toothed blade.
Warren
Old Jan 7, 2002 | 03:09 PM
arren123's Avatar
I feel lost and dumb.. What exactly are you guys talking about?
Anyone got pictures? Yoshi to the rescue ??
Old Jan 7, 2002 | 06:46 PM
gamby's Avatar
Default Re: How did you make the slash cut on the feedback air tube from the valve cover? (arren123)
It's a trick from theoldone.com that is supposed to help prevent oild blowby, It helps keep the pressure in the valve cover positive instead of negative (which sucks out oil vapor, thus burning oil).
Black R
Jan 25, 2010 07:18 PM
Mr. Em1
Welding / Fabrication
10
May 2, 2009 03:38 PM
aleks77
Sep 4, 2008 09:35 PM
k_lude
Jul 31, 2008 03:34 PM
LSVTEC 91 Civic
Jul 30, 2005 12:47 PM
