code 19 Automatic transmission lockup control valve
Old Dec 30, 2004 | 09:31 PM
peja43916's Avatar
Default code 19 Automatic transmission lockup control valve
Automatic transmission lockup control valve code 19
Can someone tell my what this means and how I fix it on my 98 Civic Lx?
Old Dec 30, 2004 | 09:33 PM
eK9aT10pSi's Avatar
Default Re: code 19 Automatic transmission lockup control valve (peja43916)
do you leak atf fluid on the ground or around the bell housing?
Old Dec 30, 2004 | 09:46 PM
peja43916's Avatar
Default Re: code 19 Automatic transmission lockup control valve (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi &raquo;</TD></TR><TR><TD CLASS="quote">do you leak atf fluid on the ground or around the bell housing?</TD></TR></TABLE>
NO
Old Dec 30, 2004 | 10:45 PM
hatchi's Avatar
did you try to reset it first??
Old Dec 30, 2004 | 10:52 PM
peja43916's Avatar
Default Re: code 19 Automatic transmission lockup control valve (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">did you try to reset it first?? </TD></TR></TABLE>
I reset it a couple of times by unplugging the ECU and it still comes back
Old Dec 30, 2004 | 11:43 PM
tca0bell's Avatar
hey sorry to jack your thread but so if i have a o2 sensor code coming up it might be wrong? so i just have to reset it and see if its wrong?
badboy409
Mar 30, 2005 07:15 PM
jdmefhondachassis
Jun 23, 2004 04:11 PM
CiViC SiR
Apr 11, 2004 01:16 PM
lakerschamp2000
Mar 7, 2004 02:17 PM
blackcruzan
Dec 10, 2003 09:30 AM
