Distributor Rotor
Old Dec 30, 2004 | 09:27 PM
mikester_91's Avatar
Default Distributor Rotor
Could an old distributor rotor (130,000 miles) be makin my car run kinda crappy? Like hesitation and ****? Just curious.]
Old Dec 30, 2004 | 11:28 PM
Altilude's Avatar
Default Re: Distributor Rotor (mikester_91)
https://honda-tech.com/zero...age=2
yes it could... take it out and have a look at it, or better yet put one end of a multimeter probe at the metallic center of it, then run another probe down the length of the blade (the skinny edge that passes the distributors "points") - if you get intermittent continuity I would consider replacing it....
mine (as seen somewhat blurry in the link I provided above) was quite coroded.. only about 1/3 of the blade was conductive. this can lead to misfiring..., or a lower intensity spark ...which sux.
test the cap continuity from the plug end thru to the points inside the cap, also - look for cracks in the cap...
It's monkey proof so you can't screw up the installation of a new rotor (as long as you haven't taken the drive end a apart)... new rotor's are also cheap - so it's a recommended job
if you don't have a timing gun yourself, mark the timing of the distributor to the block, before removing the distributor - OR, just remove the cap, and leave the distributor mounted. I like to take everything apart and look at it, so I usually take the whole thing off...
if you read my entire thread above - you'll see getting your engine timed correctly might help your hesitation and crap running.
Best of luck.
William1991b
Oct 9, 2011 07:44 PM
yangkm
Feb 26, 2011 04:20 PM
Partizan
Jan 21, 2008 06:10 PM
Japanese1.6
Apr 10, 2005 08:42 AM
