del sol radiator in a 00 civic si
Old Dec 30, 2004 | 09:25 PM
JMinSi2000's Avatar
Default del sol radiator in a 00 civic si
Will this bolt in without modificiations? The del sol radiator is $100 cheaper than the civic radiator at autzone.
Old Dec 30, 2004 | 09:29 PM
eK9aT10pSi's Avatar
Default Re: del sol radiator in a 00 civic si (JMinSi2000)
yes, make sure the one you get is a del sol dual core one. goes in with no problem. you might need to bend up the frame a bit. [when you put the radiatior in, youll see, its real easy with some pliers]
Old Jan 6, 2005 | 01:17 PM
JMinSi2000's Avatar
Are the radiator hoses different sizes for the 00 Si's and a Del Sol? I put the Del Sol radiator in from Autozone, and my hoses are too big. I used hose clamps to tighten them down but theyare leaking.
Old Jan 6, 2005 | 07:21 PM
JMinSi2000's Avatar
ttt
Old Jan 7, 2005 | 10:44 AM
eK9aT10pSi's Avatar
its a direct fit, the lines go the same way, no issue.
the soL that could
12
Mar 25, 2006 03:58 AM
NXSpoon
Apr 9, 2005 09:46 PM
phantom_sol
10
Apr 28, 2003 05:53 PM
