i cant get my trans OFF!!!
Old Dec 30, 2004 | 05:54 PM
jbell's Avatar
Default i cant get my trans OFF!!!
took out all the bolts.
the rear mount
the midshaft
its like 1" off the block now, and WONT COME OFF @#&!*@#%
i tried a prybar, and it just pivots... that side will open, but the other side closes up...
if i put somehting in the other side, nothing happens.
Old Dec 30, 2004 | 05:59 PM
Jimmy's Avatar
Global Moderator
Use a little bit of pressure from the jack..
I had the same problem the first time i took my S20 tranny off.
I put the jack under the tranny and then used a pry bar and pryed and it eventually came off
Goodluck & PM me if you have any more questions.
jbell's Avatar
Default Re: (Jimmy)
i'll give that a shot in a bit.. im tired.
Old Dec 30, 2004 | 06:11 PM
jbell's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Use a little bit of pressure from the jack..
Goodluck & PM me if you have any more questions.</TD></TR></TABLE>
no dice.
Old Dec 30, 2004 | 06:21 PM
maxspeedhonda's Avatar
Default Re: (jbell)
Two stupid suggestions:
Is the tranny mount(s) off not just rear?
Are you sure you removed all of the bolts? Start on one spot on casing and work all the way around.
Remember that there is a splined shaft running through that. If you doing pull on it straight, it will not come out. I would keep trying to play with the jack. Get under there and wiggle it back and pull while pulling. If you have all the mounts and bolts out, then that is the only thing holding it in.
Old Dec 30, 2004 | 06:54 PM
BignevadaBoB's Avatar
Default Re: (jbell)
did you remember to take off the flywheel cover thing under the tranny where it connects to the block
Old Dec 30, 2004 | 07:04 PM
jbell's Avatar
Default Re: (BignevadaBoB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BignevadaBoB &raquo;</TD></TR><TR><TD CLASS="quote">did you remember to take off the flywheel cover thing under the tranny where it connects to the block</TD></TR></TABLE>
i thought that could stay on...
and i removved all the bolts... the trans is like 1" off the block.
Old Dec 30, 2004 | 07:42 PM
cherroneballs's Avatar
if you have it all disconnected just work your jack up and down and pry as you go up and down and side to side.
they are a bear, even when the whole engine and trans is out of the car.
Old Dec 30, 2004 | 07:50 PM
Blazin Civic's Avatar
Default Re: (cherroneballs)
Also sometimes that dowel pin can be a pain in the ***.
Old Dec 30, 2004 | 07:51 PM
stormy's Avatar
Default Re: (jbell)
The lower header bracket will rub of the flywheel cover until you remove it
Also don't forget the starter has a bolt that runs into the block as well
Old Dec 30, 2004 | 08:10 PM
Kamin's Avatar
Default Re: (sans)
the starter, take it off.
Old Dec 30, 2004 | 08:16 PM
doublejz's Avatar
Default Re: (Kamin)
yea check the starter bolt, and the black metal dust shield thing on the bottom that goes over the tranny and block. Both of those could be causing your problem.
Old Dec 30, 2004 | 08:36 PM
M15's Avatar
M15
Default Re: (doublejz)
Sorry to infringe on this guys thread but I am also taking off my transmission and it appears that I have stripped teh bolt that holds on the shift cable(automatic) and I have tried everything to get it off any ideas? If necesary I can provider a picture.
Old Dec 30, 2004 | 08:47 PM
hatchi's Avatar
Default Re: (M15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M15 &raquo;</TD></TR><TR><TD CLASS="quote">Sorry to infringe on this guys thread but I am also taking off my transmission and it appears that I have stripped teh bolt that holds on the shift cable(automatic) and I have tried everything to get it off any ideas? If necesary I can provider a picture.</TD></TR></TABLE>
Drill it out
Old Dec 30, 2004 | 08:49 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (jbell)
[QUOTE=jbell]
it can't. It's bolten to the tranny, and is behind the flywheel...remove it
Old Dec 30, 2004 | 08:55 PM
M15's Avatar
M15
Default Re: (Evs-One)
How would I o about drilling it out, sorry never had to deal with stripped bolts before.
Old Dec 30, 2004 | 09:14 PM
I8ayellowcrayon's Avatar
If the starter was still connected, it wouldn't move 1" from the block.... Try setting the motor on the floor sitting on its oil pan, and get a pry bar on both sides and just go back and forth. Thats what I always do. Getting it back on the block is the tricky part .
Old Dec 30, 2004 | 09:20 PM
jbell's Avatar
Default Re: (I8ayellowcrayon)
yeah.. the motor is out of the car...
im gonna take that black flywheel cover thing off.
Old Dec 30, 2004 | 09:22 PM
Civic92Turbo's Avatar
b-series motor?
Old Dec 30, 2004 | 09:26 PM
jbell's Avatar
Default Re: (Civic92Turbo)
b16a3
lsturbo*
Mar 3, 2008 02:02 PM
LoW ToNE
12
Jan 17, 2008 07:47 AM
Mistermark
May 1, 2006 02:45 PM
Pete_SI
18
Jul 28, 2005 05:47 AM
tallblondkid
Aug 10, 2004 10:25 PM
