92 trany swap
Old Dec 30, 2004 | 05:47 PM
B.D's Avatar
B.D
Default 92 trany swap
Can I swap my 92 h23a1 from a auto to std
Old Dec 30, 2004 | 07:07 PM
Dougs96SI's Avatar
Default Re: 92 trany swap (B.D)
Yes you can do it if you buy a new tranny which will cost a good chunk of change, but not as much as the labor will be if you have someone install it. If you want to you should go for it, it will definitely be the best mod you can ever make. You have to install clutch lines, master cylinder, slave sylinder, oh yeah and drill through your fire wall and put in that all important third pedal, and buy a clutch flywheel and new tranny, but if you are up for it - go for it and post pics of the install.
Also try the search feature at the top right corner of the homepage and you will find a ton of information.
Good Luck
Old Dec 30, 2004 | 08:03 PM
B.D's Avatar
B.D
Default Re: 92 trany swap (Dougs96SI)
Will the shift linkage line up and work or will I need to cut and mod.
Old Dec 30, 2004 | 08:39 PM
B.D's Avatar
B.D
Will the old ECU and shafts work will I need to change the wireing.
This is my first import I am a hot rod guy but wanted to do something different.
So I bought a nice 92 h23a1 lude the auto is sliping and want to swap.
I work in a machine shop and have big plans for the little car.
Old Dec 30, 2004 | 09:13 PM
Speedra500's Avatar
you need a 5spd ecu and new shift linkage
Old Jan 3, 2005 | 06:16 AM
mikester_91's Avatar
B.D. I'm from missouri too, i live about 80 miles away from you. -92 lude si
925EKCOUPE
Jun 17, 2009 07:49 PM
killin me smalls
Jul 2, 2006 03:53 PM
bartek_b
Acura TL, RL & ZDX
Oct 18, 2003 01:40 AM
