Power Windows are really slow in the freezing cold
Old Dec 30, 2004 | 05:13 PM
01SSAP1's Avatar
Default Power Windows are really slow in the freezing cold
I have 2000 EM1
When it is really cold like -10 C or below my power windows work badly.
They are really slow.
They work a little better when it is warmer.
In general Honda Power Windows seem to suck. Maybe it is just Civic ones.
Anybody else have problems with the power windows when it is really cold.
Old Dec 30, 2004 | 05:17 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Power Windows are really slow in the freezing cold (2KCivicSiR)
Have you been lubricating them regularly like you're supposed to do with the silicone spray?
Modified by 00Red_SiR at 10:28 PM 12/30/2004
Old Dec 30, 2004 | 05:20 PM
01SSAP1's Avatar
Default Re: Power Windows are really slow in the freezing cold (00Red_SiR)
Should look into that?
What kinda spray should I get?
Where do you spray it?
Old Dec 30, 2004 | 05:21 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">Have you been lubricating the regularly like you're supposed to do with the silicone spray?</TD></TR></TABLE>
I was amazed that there was actually a maintenance schedule for these damn things. I guess I'll pull my foor panels off one day and lube them up. It's been almost 5 years and 58K miles. I think they're about due.
Old Dec 30, 2004 | 05:27 PM
00Red_SiR's Avatar
All Motor Mentor
You can get the spray from Canadian Tire, it's in a generic CT "Motomaster" red spray can with a white top on it and it's called "silicone spray" or dry silicone spray or something like that. It also has a spray tube that comes with it on the can like WD-40 does. You don't need to take your door apart to do it just stick the spray extension tube down into the window channels and give it a real good spray for a couple seconds. Spray down at the back of the window and the front part of the window where it slides down into the door. Do this everytime you change your oil or a little more frequently if you find the windows starting to bind up on you and slow down.
Old Dec 30, 2004 | 05:29 PM
01SSAP1's Avatar
Default Re: Power Windows are really slow in the freezing cold (IslandSi)
Do you need to remove the door panels to spray the tracks with silicone?
Or can you just spray the tracks the window goes into in the top half of the door? (Door Window Frame)
Old Dec 30, 2004 | 05:31 PM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote"> You don't need to take your door apart </TD></TR></TABLE>
01SSAP1's Avatar
Thanks Red
It is nice to get good advice from a fellow Nova Scotian.
Someday maybe next summer it would be cool to met you and see your car
If you were interested
Old Dec 30, 2004 | 05:35 PM
00Red_SiR's Avatar
All Motor Mentor
yep for sure, I'll definitely be around. I'm working on doing a JDM ITR swap over the winter (or some variation of it) plust some S2 stage 2 cams and a few other upgrades, so I should have it at the track for a few good runs I would think.
Old Dec 30, 2004 | 05:36 PM
01SSAP1's Avatar
Cool
You goto Shubie?
Old Dec 30, 2004 | 05:40 PM
00Red_SiR's Avatar
All Motor Mentor
yep I do, but I'll probably hit the drag strip a bit more since that'll be a better place to enjoy the car's upgraded power. Last time I was Shubie my tires were literally melting from driving...lol
Old Dec 30, 2004 | 05:42 PM
litterbox's Avatar
I am a (Trial User) Army
Fellow Canadian checking in!
Old Dec 30, 2004 | 05:45 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Power Windows are really slow in the freezing cold (litterbox)
Hey George! you may be a displaced Canadian but you're still considerd an easterner...lol
Old Dec 30, 2004 | 06:12 PM
01SSAP1's Avatar
Where is the drag strip?
Don't think I have been there before
Old Dec 30, 2004 | 06:31 PM
00Red_SiR's Avatar
All Motor Mentor
There's one down in Liverpool/Bridgewater known as Greenfield, it's an old air strip. Then the other is in PEI at Oyster Bed Bridge. Sydney has one too but I've never been to that one before.
Old Dec 30, 2004 | 06:47 PM
eJone powereD's Avatar
just lubricate the rubber tracks that hold in the window...
this is what i used on mine...not sure if u can get it in stores since my dad just came home with it from his work one day...
my windows are like new and dont slow down when its cold
urkuletz
Honda Civic (2001 - 2005)
Dec 14, 2007 05:47 AM
tampabitches
Feb 1, 2007 01:03 PM
Jay J
Apr 21, 2006 01:00 PM
Mr Fatty
Nov 26, 2005 10:48 AM
GetawayInMoscow
Jun 28, 2004 05:42 PM
