will this turbo work on a b series?
Old Dec 30, 2004 | 04:59 PM
xxscaxx's Avatar
Default will this turbo work on a b series?
Will a IHI RHB5 VJ11 work with a b16? i bought this turbo thinking it was a t3 (so did the guy) and its from a ford probe. its ball bearing im just not sure of the hp capability or if its too small of a turbo
Old Dec 30, 2004 | 05:07 PM
eK9aT10pSi's Avatar
Default Re: will this turbo work on a b series? (xxscaxx)
itd work but good luck on getting a manifold with that flange style
Old Dec 30, 2004 | 06:54 PM
fishnfst's Avatar
check out homemadeturbo.com. That seems to be a very popular turbo over there for a diy project......
Old Dec 30, 2004 | 06:58 PM
2fast4u831's Avatar
I'm really 2slow
Those are mostly used on D-series engines with the cx/vx manifold and an adaptor plate
Old Dec 30, 2004 | 11:42 PM
xxscaxx's Avatar
Default Re: will this turbo work on a b series? (2FAST4U831)
i know, im having trouble getting the flange i have to make an adapter plate. ive seen that these are used more so for the d series. you think its worth it? you think it will boost good?
Old Dec 30, 2004 | 11:47 PM
SiKid86's Avatar
any turbo will work just as long as you can get a mani for it! The thing is how pratical will it be for you!
Old Dec 31, 2004 | 06:39 AM
blackeg's Avatar
Default Re: will this turbo work on a b series? (SiKid86)
rhb5 is entirely to small for a b16. my friend has one almost maxxed out on his 2 liter golf, and that motor flows less than your b16. the rhb5 will more than likely run out of power around 7k rpms, and anything over moderate boost. it is however a bad *** turbo on a car that fits it better.
bottom line, you can use it, but it will kinda be shitty on a b16.
Old Dec 31, 2004 | 07:24 AM
rcoolb2002's Avatar
Default Re: will this turbo work on a b series? (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">rhb5 is entirely to small for a b16. my friend has one almost maxxed out on his 2 liter golf, and that motor flows less than your b16. the rhb5 will more than likely run out of power around 7k rpms, and anything over moderate boost. it is however a bad *** turbo on a car that fits it better.
bottom line, you can use it, but it will kinda be shitty on a b16.</TD></TR></TABLE>
to what he said. I have two of these turbos, one on my turbo mx6. There is no published flow ratings or charts for the turbo but It is generally agreed that the number falls somewhere between 190 and 280 cfm max flow. On the mx6 (2.2l) the turbo loses efficiency @ 5500rpms, and cant sustain more than around 15 psi of boost. I would definitely suggest a different turbo for a b16.
Old Dec 31, 2004 | 01:12 PM
xxscaxx's Avatar
Default Re: will this turbo work on a b series? (rcoolb2002)
well that sucks a lot....
knowing that...
anyone want to buy it? lol
how much are they worth rcoolb2002 since you have two of them. the one i have is in perfect condition and has no shaft play at all.
Old Dec 31, 2004 | 01:20 PM
rcoolb2002's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxscaxx &raquo;</TD></TR><TR><TD CLASS="quote">well that sucks a lot....
knowing that...
how much are they worth rcoolb2002 since you have two of them. the one i have is in perfect condition and has no shaft play at all.</TD></TR></TABLE>
I would advertise is on http://www.probetalk.com and http://www.mx6.com I think you could probably get $100 or so for just the turbo itself if its GREAT condition.
Old Dec 31, 2004 | 04:20 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcoolb2002 &raquo;</TD></TR><TR><TD CLASS="quote">
to what he said. I have two of these turbos, one on my turbo mx6. There is no published flow ratings or charts for the turbo but It is generally agreed that the number falls somewhere between 190 and 280 cfm max flow. On the mx6 (2.2l) the turbo loses efficiency @ 5500rpms, and cant sustain more than around 15 psi of boost. I would definitely suggest a different turbo for a b16.</TD></TR></TABLE>
http://www.ihi-turbo.com/turbo_RHE-RHF.htm
there are some maps and **** for the rhf5, which is the same as an rhb5, just newer. you just have to convert to cubic meters/second.
Old Dec 31, 2004 | 04:36 PM
AP1 John's Avatar
i think any turbo will work
91EFate
May 12, 2005 09:03 PM
wpgcivic
Feb 6, 2005 07:42 PM
DrewDown
Oct 20, 2004 06:48 PM
sanfriz
May 3, 2004 04:56 PM
Del_Sol_s
Oct 26, 2003 12:00 PM
