steps to install a trubo kit on a lude
hey, is there anyone out there who wants to walk me through the steps of installing a turbo kit...i want to print the instructions off so i can study them and maybe even do the kit myself....so if someone could walk me through step by step that'd b awsome, thanks!
hmm its not soo hard doGG u can just get a turbo kit and u know water line, oil line and join it to the head and also take care of the partsof turbo kits............just go 2 a mechanic and tell him 2 do ur work dont do it ur self well i install my turbo kit myself.cuz i just know wat 2 do.just put the pipes to the intercooler and one from the intake.thanks anything wrong tel me.
it's not as hard as you guys make it seem...take off the intake and header. get oil pan tapped for the oil return line. tap the back of the block at the oil sensor for oil feed line. slap on the mani/turbo and mount the intercooler and run the pipes. then run the vacuum lines for wastegate and blowoff valves. then fueling is another story...that depends on what fuel setup u have....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 »</TD></TR><TR><TD CLASS="quote">it's not as hard as you guys make it seem...take off the intake and header. get oil pan tapped for the oil return line. tap the back of the block at the oil sensor for oil feed line. slap on the mani/turbo and mount the intercooler and run the pipes. then run the vacuum lines for wastegate and blowoff valves. then fueling is another story...that depends on what fuel setup u have....</TD></TR></TABLE>
How about if you were to fit the turbo kit yourself following instructions from a dedicated turbo intall manual and then get it checked set up by a pro and used uberdata for the fueling and maby a fuelrail + Fpr?
as i am going to attempt this myself also as i would have to pay £1200 fitting then £400+ for set up and dyno time which a cannot afford.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottle fed »</TD></TR><TR><TD CLASS="quote">SEARCH!!!!!!</TD></TR></TABLE>
Wow i bet that took you ages to think up, do you think nobody already did this!
its real easy just buy the most expensive parts for the best kit possible.!
and hope it all fits and keeping ac ofcourse.
, or take it to a shop
