my left light keeps going out why?
i have an 00 gsr, and i keep having to buy new bulbs for my car cause the left side keeps going out. Is it my car thats causing the bulbs to go out, or is it cause the bulbs. Someone help me out cause i'm tired of spending 30 bucks a month to get new bulbs......
mine does the same thing with my 92' i have hid projectors and the left one goes out but it'll come back on after i turn the lights off then on. but after the bulbs adjust it just shots off again. im thinkin the wattage is off or something like that but i dont really know much about electrics.
if the problem persists, rewire it by using a new harness with relays. so that the bulbs draw power directly from the battery and uses the original harness as a switch.
maybe there's a problem with the light housing. moisture?
is there any condensation in the light or moisture at all. My car had a very small crack it the lens and i drilled a small hole in the bottom of it to get the moisture out. Have not had to buy another bulb in about a year
i got a 00 ls and my bulbs do the same thing...i had after market bulbs and they would blow the fuse or burn out...i put my oem bulbs back in and haven't blown out but they look like crap. any one know what are some good aftermarket bulbs that give the car the HID look but aren't HIDs????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SLOWlsTEG »</TD></TR><TR><TD CLASS="quote"> any one know what are some good aftermarket bulbs that give the car the HID look but aren't HIDs????</TD></TR></TABLE>
Silverstar's are the closest you'll get to a non-hid. But they don't last long either.
Bambooseven
Mar 3, 2009 08:40 PM
