Integra Water pump
Old Dec 30, 2004 | 11:59 AM
87ludemasta's Avatar
Default Integra Water pump
I was wondering if you could put a GSR water pump on a 96' integra b18 b1 LS?
Modified by 87ludemasta at 1:18 PM 12/30/2004
Old Dec 30, 2004 | 02:18 PM
rgaray's Avatar
You would have to use a GSR timing belt.
Old Dec 30, 2004 | 06:18 PM
b18c1acura's Avatar
Default Re: (rgaray)
why would you need a gsr timing belt as well? Just curious
Old Dec 30, 2004 | 06:25 PM
garados's Avatar
Default Re: (b18c1acura)
the water pump is driven by the timing belt
Old Dec 30, 2004 | 06:28 PM
04falcon's Avatar
if you use the gsr wtr pump you have to use the gsr t-belt and the same for the ls wtr pump ls t-belt.but yes either will work on your block as long as you use the the t-belt to match the wtr pump
Old Dec 30, 2004 | 06:33 PM
NJIN BUILDR's Avatar
The gsr pump has more teeth on the pulley.
Glenn
Old Dec 30, 2004 | 11:58 PM
kikwear002's Avatar
spinning the gsr pump faster
KdF
Mar 10, 2009 05:36 PM
shortyz21
Nov 12, 2006 08:38 AM
19sec beast
Mar 31, 2006 04:40 AM
alfee
Nov 28, 2005 09:37 AM
thaiphob
Oct 31, 2003 05:24 AM
