Rusted Bolts
Old Dec 30, 2004 | 11:57 AM
iLUVmyACCORD's Avatar
Default Rusted Bolts
there are a few rusted bolts in the engine bay that i want to take off to get to some parts.. whats the best way to get these bolts off.. are there products out there that can make it easier to twist these bolts off?
thanks
Old Dec 30, 2004 | 12:18 PM
CDEEE5's Avatar
PB bolt breaker and a break bar are your best friend depending on where the bolt is you may wanna heat it up a lil bit with a propane torch
glad i got no rusty bolts
Old Dec 30, 2004 | 12:31 PM
propwdialogue's Avatar
Default Re: (CDEEE5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CDEEE5 &raquo;</TD></TR><TR><TD CLASS="quote">PB bolt breaker and a break bar are your best friend</TD></TR></TABLE>
good ideas, but you may end up shearing off the head of the bolt, in which case you will need an easy-out and a new bolt
Old Dec 30, 2004 | 03:02 PM
alotawatts's Avatar
Default Re: Rusted Bolts (AccOrd-fiZZle)
PB Blaster, Liquid Wrench penetrating oils. If you are engine swapping and have no fuel, fluids or battery near by heating the bolt head with a torch will help.
Old Dec 30, 2004 | 05:38 PM
CDEEE5's Avatar
Default Re: (propwdialogue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by propwdialogue &raquo;</TD></TR><TR><TD CLASS="quote">good ideas, but you may end up shearing off the head of the bolt, in which case you will need an easy-out and a new bolt</TD></TR></TABLE>
yea thats very tru...every situation is diferent i guess...easy-out is not a fun route to go when the heads come off the bolt thou
Old Dec 30, 2004 | 06:11 PM
98carbonaccord's Avatar
liquid wrench!
civicservice
13
Apr 1, 2018 05:39 AM
SRd240sx
Apr 30, 2014 04:16 AM
Takumi Fujiwara
Dec 22, 2005 08:44 AM
Matgallis
Aug 25, 2004 02:36 PM
01CWITR
Aug 7, 2002 03:52 PM
