EG transmission
Old Dec 30, 2004 | 10:50 AM
Shotman's Avatar
Default EG transmission
whats up guys,
anyhow I got a 95 Civic SI (canadian) anyhow, I was wondering what year transmission i can use on my car, its stock, but the engine i got is a D15B, i replaced it from my original d16z6, now i still have the old tranny from that motor, but i need a new tranny since my currecnt one is mESSED!!! anyhow, i just need to know what transmission can fit to this engine, and btw its hydro. thanks again guys :D
Old Dec 30, 2004 | 10:57 AM
DAguyLS's Avatar
well any d series will fit, i believe.
But i think in your case you would want the Z6. It has the shortest gears, if i'm not mistaken.
Old Dec 30, 2004 | 11:00 AM
skip.two's Avatar
Default Re: EG transmission (Shotman)
yes, any D-series tranny will fit.
if you need a new tranny, get a D16Y8 tranny. best D-series tranny.
it practically has the same gearing as the D16Z6, but stronger shift forks.
Z6 tranny - aluminum shift forks
Y8 tranny - steel shift forks
Old Dec 30, 2004 | 11:27 AM
beerbongskickass's Avatar
Default Re: EG transmission (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">yes, any D-series tranny will fit.
Y8 tranny - steel shift forks</TD></TR></TABLE>
Old Dec 30, 2004 | 11:34 AM
Kendall's Avatar
Y8 &gt; Z6
There's usually a couple of each in the classifieds at any given moment.
Old Dec 30, 2004 | 11:58 AM
berettagtz117's Avatar
Poop! Ya any dseries will fit!
Old Dec 30, 2004 | 01:09 PM
Shotman's Avatar
Default Re: (berettagtz117)
thats cool, i was just wondering how much i should spend for a transmission, in either american or canadian dollars
Old Dec 30, 2004 | 03:43 PM
skip.two's Avatar
Default Re: (Shotman)
well, i see Y8's or Z6's go for somewhere around $125-$200 U.S.
Old Dec 30, 2004 | 03:56 PM
Solo2EG's Avatar
Do yourself a favour and get the Vti tranny (with LSD) from Japan, they're available in Toronto all the time, look on the TCC boards or contact Adrian at Hyperduck. I've got one in my EG and it's the best Mod I ever did (for Solo2 anyway). Should be able to find one for less than $500...
Old Dec 30, 2004 | 04:04 PM
Lord Helmet's Avatar
Default Re: EG transmission (Solo2EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solo2EG &raquo;</TD></TR><TR><TD CLASS="quote">Do yourself a favour and get the Vti tranny (with LSD) from Japan, they're available in Toronto all the time, look on the TCC boards or contact Adrian at Hyperduck. I've got one in my EG and it's the best Mod I ever did (for Solo2 anyway). Should be able to find one for less than $500...</TD></TR></TABLE>
the Vti tranny would be sweet if only if you can find them.
can't find it then I recommend the Y8 tranny
Old Dec 30, 2004 | 04:17 PM
shadowchild's Avatar
Default Re: EG transmission (sleeperciv)
I belive the D15b2 tranny in japan also has LSD, its a 1.5vtec, the swaps with tranny are
cheap so I would assume the tranny it self would be super cheap.
Xxcivic97xX
11
Feb 17, 2017 05:40 PM
89civicb16a1
Aug 27, 2006 01:57 AM
haitian1
Feb 12, 2006 09:44 PM
Suzukablue
Feb 16, 2004 12:23 PM
