SMAW welding rod sizes
Old Dec 30, 2004 | 08:26 AM
Blazeone's Avatar
Default SMAW welding rod sizes
What size/type of rod would you guys recommend for welding 3/16" thickness angle iron together?
Old Dec 30, 2004 | 09:40 AM
Engloid's Avatar
OG Fabricator
Default Re: SMAW welding rod sizes (BlazeONE)
Most common for hobby usage is a 6014 or 7014. I prefer a 6010 or 7018, but they cost a little more. I like 1/8" for the 6010 and 3/32" for the 7018.
Old Dec 30, 2004 | 11:18 AM
Blazeone's Avatar
Default Re: SMAW welding rod sizes (Engloid)
i got some 3/32" for the 7018.
Thanks
Any reccomendations for amperage?
Old Dec 30, 2004 | 01:12 PM
Canuk_SiR's Avatar
with 3/32, try 115 to start. that depends what position you're welding though.
Old Jan 2, 2005 | 08:00 PM
rexsk8er's Avatar
Default Re: SMAW welding rod sizes (Canuk_SiR)
i like 1/8 6011... especially when the metal is rusty/dirty
i also like 1/8 7018's because thier ease, but its a pita over head caus they allways stick....
but for what your doing id go with 3/32's 7018s like advised
Old Jan 2, 2005 | 08:41 PM
Engloid's Avatar
OG Fabricator
Default Re: SMAW welding rod sizes (rexsk8er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rexsk8er &raquo;</TD></TR><TR><TD CLASS="quote">i like 1/8 6011... especially when the metal is rusty/dirty
but for what your doing id go with 3/32's 7018s like advised</TD></TR></TABLE>
The 6010 will burn very similar to the 6011. If you can weld with one, you can weld with the other. As for the 7018's....if you have trouble with them sticking, turn up the heat a bit
Also, keeping the rods warm will help them start up. Sometimes, I will hold the end of the rod to the ground, then hold the electrode holder to the other end of it for a couple seconds to preheat it....then strike it and go. You gotta be careful though...they heat up really fast doing this.
RACEPAK
Nov 3, 2008 06:52 AM
Oregon
Welding / Fabrication
Nov 23, 2006 06:36 AM
EJ8kid
May 6, 2006 08:24 PM
Boostage
Jan 5, 2005 06:01 AM
infinatenexus
13
Oct 2, 2003 08:42 AM
