Stock HU Remote Turn On Wire
I've installed several systems but tomorrow am doing one with the stock Honda headunit. Its a 00 Civic, I went to the12volt.com site but I wasn't sure which one to use. Should I tap the Constant 12v (blue/white wire) or the Switch 12v (yellow/red wire)? Sorry for the retarted easy question but I'm figuring someones got 2 seconds they can give me! Thanks!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiBuddy00 »</TD></TR><TR><TD CLASS="quote">I've installed several systems but tomorrow am doing one with the stock Honda headunit. Its a 00 Civic, I went to the12volt.com site but I wasn't sure which one to use. Should I tap the Constant 12v (blue/white wire) or the Switch 12v (yellow/red wire)? Sorry for the retarted easy question but I'm figuring someones got 2 seconds they can give me! Thanks!!</TD></TR></TABLE> Check the fuse box for an acc. freepin.
94
94
I think your honda has a remote turn on (ie power antenna wire)
I dont know of the color off hand But you can find out...If the car
does not have an antenna on the drivers a pillar look at the rear glass
along the defroster grinds do u see ant extra wires? If so pull off the
rear passenger window cover trim off you will find the ant amp. That is your color.
Or if you want...pull the deck and use a meter to see which wire gives output
voltage when the radio goes on.
6KAOS6
26
Feb 19, 2011 07:22 PM
