can you tell if a car is in good condition w/o the head???
Old Dec 29, 2004 | 10:12 PM
Andrewm224's Avatar
Default can you tell if a car is in good condition w/o the head???
I am going to look at a gsr tommmorw... The only thing is, is that it doesnt have a head.. He says that all it needs is a head to run.. Is there anyway of actually proving this w/o bolting on a head???
Old Dec 29, 2004 | 10:18 PM
Cjsls's Avatar
Default Re: can you tell if a car is in good condition w/o the head??? (Andrewm224)
look at the cylinder walls(attn to cross-hatching), u could measure the cyl bores(see if they're out of round), check the block surface deck make sure its flat, spin the crank pulley make sure the crank turns freely. but all that is just for reassurance that it "MIGHT" run okay after you put a head on. It could still have bad bearings, bad piston rings, a bad oil and water pump.....BUT that doesn't mean it won't run. It just won't run good.
pinoy_93cb7
Jul 6, 2011 01:29 PM
SUB-0 H23
Jan 22, 2004 09:48 AM
chictunner97ex
Jul 8, 2003 05:32 PM
QCKGSR
Apr 14, 2003 06:49 PM
