who do you think the top k series tunner is?
Old Dec 29, 2004 | 09:21 PM
SoCaLNaTIvE's Avatar
Default who do you think the top k series tunner is?
i would like to know who the top k series tuner/builder is, but here are the rules. the tuner needs to have made this power using pump gas, and the car needs to remain reliable.
if you could post links and or the tuners accomplishments with the k series format.
thanks for the help
Old Dec 30, 2004 | 08:50 AM
krystar's Avatar
a guy in bogota has 650whp in his built k20a2 turbo. ....how's that for most power.
Old Dec 30, 2004 | 10:05 AM
Default Re: (krystar)
that is sick power, but i am thinking more along the lines of na on pump gas.
Old Dec 30, 2004 | 04:55 PM
K20Ahondas's Avatar
Default Re: who do you think the top k series tunner is? (SoCaLNaTIvE)
242whp (DYNOJET)stock long block with ITR cams.
Old Jan 2, 2005 | 11:22 AM
Default Re: who do you think the top k series tunner is? (K20Ahondas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20Ahondas &raquo;</TD></TR><TR><TD CLASS="quote">242whp (DYNOJET)stock long block with ITR cams. </TD></TR></TABLE>
these are your accomplishments? what shop? so the only upgrade is itr cams and tuning? could you be a little more vague, and a little less helpful?
Old Jan 3, 2005 | 11:08 AM
EFDawg's Avatar
That is Norris Prayoonto. He runs a 9 second all motor drag car. Look him up online and you may learn something.
Old Jan 3, 2005 | 01:05 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Realtime Racing
Old Jan 3, 2005 | 03:06 PM
TheShodan's Avatar
Moderator
Default Re: who do you think the top k series tunner is? (vtecvoodoo)
http://www.hondawerx.com
Greg has a customer with a em2 with a k20a Fully built type r block 9/1 88mm bore gt30 turbo car that makes about 600whp at 20 psi. I think i was making 400 at 10 pounds.
Old Jan 3, 2005 | 03:59 PM
civicgsir's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCaLNaTIvE &raquo;</TD></TR><TR><TD CLASS="quote">i would like to know who the top k series tuner/builder is, but here are the rules. the tuner needs to have made this power using pump gas, and the car needs to remain reliable.
thanks for the help </TD></TR></TABLE>
I would have to go with John over @ HYTECH. the 2 K's that they have done have been retarded.
first was the K20a that was 265whp / 173ft lbs on 91 octane.
this was back in May 2003
then came the K24 that had over 300whp
Old Jan 3, 2005 | 04:04 PM
k20whitevic's Avatar
Default Re: who do you think the top k series tunner is? (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">http://www.hondawerx.com
Greg has a customer with a em2 with a k20a Fully built type r block 9/1 88mm bore gt30 turbo car that makes about 600whp at 20 psi. I think i was making 400 at 10 pounds. </TD></TR></TABLE>
I thought his "new" setup consisted of a gt35?
Also, I thought the Whip Factory did most of the building/redoing of the turbo setup, as well as the actual tuning of that car?
Old Jan 3, 2005 | 04:12 PM
CivicEM's Avatar
Default Re: who do you think the top k series tunner is? (k20whitevic)
I would say go with Hondata. My buddy has K20 in his EG and it is powerful. All he does is plug the laptop in and you can change just about every setting on the ECM, from turning sensors on/off and changing fuel maps. Its cold and wet in Chicago but when its warm out there is more tuning to come.
Old Jan 3, 2005 | 08:47 PM
EFDawg's Avatar
Default Re: who do you think the top k series tunner is? (civicgsir)
OH, the ones that they were going to release the engine kits for? lol
monkeymk2
Oct 30, 2016 01:40 AM
kenny7231
Jan 9, 2008 08:23 PM
Nikos
12
Jan 31, 2005 12:46 PM
