buying tranny.. Need advice.
Old Dec 29, 2004 | 07:10 PM
HamiltonRex's Avatar
Default buying tranny.. Need advice.
i found someone local selling a jdm y1 lsd trans. The price is fair.
He says its great shape, only used for 1yr before he went with hydro setup. No grinds really smooth etc...
Now How to tell if it really has LSD or if LSD is still good?
I searched and found if theres no bar going though where the axles slide in that its lsd.. If you can see right though.. Also that if you spin one axle the other one goes in the same direction.. that means LSD.. Right???
Okay not to test the tranny itself.
I was thinking of poping an axle in, and spinning the tranny though all the gears, and seeing how smooth it feels. I know this is no indication to the syncros.. But hes local and im doing a pickup at his residence so i could always go back if its junk. But to do a quick test first.
Now he says it comes with axles and intermediate shaft. I will have to pop these out to do a visual on the LSD, best way is just a small crowbar right?
Thanks.. hopefully in a few days i can say goodbye to peg-leg.
Old Dec 29, 2004 | 08:05 PM
Default Re: buying tranny.. Need advice. (HamiltonRex)
common im going to pick it up soon!
Old Dec 29, 2004 | 08:14 PM
smash fascism's Avatar
LSD will be stamped on the transmission. If it's not stamped then he either put one in himself or is putting one over on you.
smash
Old Dec 29, 2004 | 08:17 PM
Default Re: buying tranny.. Need advice. (smash fascism)
alright cool. where to look on the tranny? Im assuming its like a engraved style LSD stamp right in... Is it 'LSD' or something else??
Details, details..
Old Dec 30, 2004 | 01:54 AM
davens's Avatar
The stamp is the quick easy unreliable way to ID a LSD tranny. Too bad it comes off with age, gets hidden by dirt/oil/grease and can be replicated ridiculously easily.
And while I've seen the stamp on later hydraulic trannys, I'm not 100% sure it was the on cable models.
Pop off the axle, it's the best way.
Old Dec 30, 2004 | 06:46 AM
EFSiR's Avatar
check pm
Old Dec 30, 2004 | 07:16 AM
Kwicko's Avatar
Default Re: buying tranny.. Need advice. (EFSiR)
Yup, look through the differential, where the axles go in. If there's no obstruction and you can see all the way through the hole, it's an LSD. If there's a bar running across the hole about midway down, no LSD.
Mike
Old Dec 30, 2004 | 07:38 AM
hahagasdcrx's Avatar
Default Re: buying tranny.. Need advice. (Kwicko)
borrowed from ninety2sir
LSD
Most y1's have the LSD stamped on top of the tranny like your engine is stamped. Some are ink stamped and ink fades after time.
hondaZvic
Apr 24, 2006 12:27 PM
HamiltonRex
Dec 29, 2004 09:09 PM
b2Ovtec
Dec 10, 2004 10:28 AM
OldSchoolSwap
Mar 6, 2003 07:23 AM
Islander9407
Jan 7, 2002 06:40 PM
