tail lights not working
Old Dec 29, 2004 | 06:24 PM
slammeddelsol95's Avatar
Default tail lights not working
i just bought a 91 dx hatch for 200 bux it runs great but i cant figure out why the tail light arent working when i turn on the light they dont light up but when i hit the brakes they light up .
Old Dec 29, 2004 | 06:40 PM
PHOBIA's Avatar
go grap a voltameter or and start following the wires back to the harness, it could also be that the bulbs are burnt out or the fuses are shot.if that doesnt work oh well only drive during the day when you dont need running lights
Old Dec 30, 2004 | 06:06 AM
Default Re: (PHOBIA)
thanx
Old Dec 30, 2004 | 07:13 AM
Kwicko's Avatar
Default Re: (slammeddelsol95)
Do your instrument cluster lights work? I've had a problem in the past with the fuse popping (on an '88 CRX Si). That fuse, on my car at least, ran the instrument lights, the parking (corner) lights, and the taillights.
I never did completely figure out what the problem was, but I suspect water getting in the taillights. When it got wet out, I'd have a problem.
Mike
Old Dec 30, 2004 | 07:46 AM
hahagasdcrx's Avatar
Default Re: (Kwicko)
check to see if you have a dual filament bulb in there. Sometimes people replace the brake lights with a single filament bulb which will only light up when you push on the brake, The bulb you need in there is a 2057 which if you look at the bottom has 2 contacts on the bottom. Some people use a 1156 bulb which is wrong but looks the same besides the dual contacts/filament. Try that and if you still have a problem, look into your fuses and wiring.
mini_eg_monster
10
Oct 26, 2011 04:54 PM
Figgy1682
Oct 15, 2011 04:13 PM
xionl1350
Honda S2000
12
Jul 17, 2008 05:16 PM
em2power
Honda Civic (2001 - 2005)
Jan 5, 2008 07:17 PM
95integrags-r
Mar 30, 2006 05:41 PM
