coilover install
Old Dec 29, 2004 | 05:01 PM
soon2b's Avatar
Default coilover install
My friend just got a set of arospeed coilovers. I have a couple questions about the install process. The rubber bushing that fits in the top of the spring, does it have to be used. We tried to use it and then you could not get the threaded rod back thru to put the nut on the rod. Secondly when we tried to put one on, (with out the red piece) First the coil over was just sort of setting loosely, then you got almost no adjustment either way and the suspension was beyond rough it was like you had a steel tube there instead of a shock. Any help would be appreciated
Thanks
Old Dec 29, 2004 | 05:12 PM
McLovin's Avatar
u dont need 2 use that rubber bushing. im pretty sure. i didint.
Old Dec 29, 2004 | 06:24 PM
ridexstraight's Avatar
Default Re: (Russianwonder32)
all that i used on my install was that i cut tthe facotry bumpstop in half, and i used the metal hat that kame with the coil over i didnt ne of the o-rings, or rubber bushings
Old Dec 30, 2004 | 07:59 AM
soon2b's Avatar
what is the bump stop actually. What could we have did wrong that would have not allowed us any adjustment at all on one of them. thanks for the help
Old Dec 30, 2004 | 09:53 AM
blo2k1's Avatar
Default Re: (soon2b)
mine are loose in the rear too ! but mine still lowers wanna know the answere to this also
Old Jan 2, 2005 | 08:33 AM
Default Re: (blo2k1)
the bump stop is a lil rubber piece that is there so when u bottom out your strut u dont damage it u hit the stop and its about 2.5 inches tall so u cut it down because ur lowering the ride hight so u gain about an inch of travel on your strut so u have a beter ride
kyleag989
Honda Civic (2001 - 2005)
Feb 5, 2018 03:20 PM
superslow-oto
Suspension & Brakes
Jul 27, 2006 10:55 AM
ammob16
Nov 11, 2005 11:25 AM
TrueZen
Jan 17, 2003 09:22 PM
Prevail
Jun 30, 2002 01:15 AM
