Need to pull clutch/pp in CRX does it come out the bottom or the top?
Old Dec 29, 2004 | 03:04 PM
apexinghonda's Avatar
Default Need to pull clutch/pp in CRX does it come out the bottom or the top?
Did a search with several phrases and could not get any results. Have a Spec clutch/PP set up which needs to come out. Think a strap on the PP failed (after 5 hours on track). Someone else put it all in when I did my hasport tranny conversion to drop in a jdm ITR tranny into the 88 CRX B18c . Does that sucker have to come out of the bottom or can it come out the top? Any tricks or things to look out for? Trying to figure out whether to tackle it in my garage or let my mechanic do it. TIA.
Barry H.
Old Dec 29, 2004 | 03:08 PM
EL Vap133's Avatar
Default Re: Need to pull clutch/pp in CRX does it come out the bottom or the top? (apexinghonda)
Easiest way to do it is through the bottom, if you only pull the tranny out.
Old Dec 29, 2004 | 03:10 PM
Default Re: Need to pull clutch/pp in CRX does it come out the bottom or the top? (EL Vap133)
Thanks. How big of a "bitch" is it?
Barry H.
Old Dec 29, 2004 | 03:11 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apexinghonda &raquo;</TD></TR><TR><TD CLASS="quote">Thanks. How big of a "bitch" is it?
Barry H. </TD></TR></TABLE>
How much patience do you have and how strong are you? You might want to use a seperate jack to lift/lower the tranny.
Old Dec 29, 2004 | 03:16 PM
LOL. I am an old fart (48) so I while I like turning a wrench (now that I have a garage but "cook book" mechanical skills) blowing out my back (again from foolish younger days) ain't my style. Sears racing jack for the tranny from below. Have some time to spare this weekend. Would love to learn to do this myself with a buddy than paying someone.
Barry H.
Old Dec 29, 2004 | 03:25 PM
NCchris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apexinghonda &raquo;</TD></TR><TR><TD CLASS="quote">LOL. I am an old fart (48) </TD></TR></TABLE>
Me too (54) Last time I did mine, I took it out the bottom by myself. If I had a cherry picker, I think I would just remove the engine and tranny as a unit and work on it out of the car. There is no way to balance that tranny on a jack and massage (muscle) it into place. Lift your car as high in the front as your jack will go and use jackstands. You will need room to put the tranny on your chest and shimmy under the car then lift it into place! Heavy too!
HTH
chris
Old Dec 29, 2004 | 06:59 PM
Default Re: Need to pull clutch/pp in CRX does it come out the bottom or the top? (NCchris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCchris &raquo;</TD></TR><TR><TD CLASS="quote"> You will need room to put the tranny on your chest and shimmy under the car then lift it into place! Heavy too!
HTH
chris</TD></TR></TABLE>
Damn Chris you are a macho man for an old fart. LOL. Hmmm, I think I will use a buddy on this one to help.
Barry H.
Old Dec 29, 2004 | 07:14 PM
shocker's Avatar
yeah it usually takes me like 4-5 hours to do tranny/clutch swappage,and im not that strong you should have no problem....
slammedz6ef
Apr 24, 2008 11:26 AM
jadkar
Aug 30, 2005 04:50 AM
ICEfas88CRX
Jul 16, 2004 10:48 AM
darchon
Jul 8, 2004 07:39 AM
94si94cx
Oct 1, 2003 10:15 AM
