best suspension set up accord
I have an accord 99 4 door and I am wondering what gear to get. I was interested in getting h & r OE sport springs paired up with some KYB GR-2 shocks. If anyone knows a better set up that isnt to painful on my wallet or if i need anything else to ensure performance and safety, ie; cambering, bumpiness...
Thanks
Thanks
what it the car's intention?
a good drag suspension would be a crappy autocross suspension.
a good track suspension would bottem out at the street
there's not universal solution
I'm a big fan of the Eibach Pro-Kits paired up with any respectible brand of shocks/struts - even oem since they are only a 1.2" drop on most Accords, which is not going to be hard on a stock strut. But I'd recommend a pair of Koni or KYBs to match up with them just for extra unf.
- Nathan
- Nathan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by osuperjohno »</TD></TR><TR><TD CLASS="quote">just for street driving, not racing or any initial d crap, im just looking for comfort and style</TD></TR></TABLE>
save ur money, dont go cheap on suspension
tein SS coilovers dont look at anything else for your type of driving
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmaccord23 »</TD></TR><TR><TD CLASS="quote">Amen to that. I'm purchasing a set next year. Sleevovers suck!
really? and why is that?
</TD></TR></TABLE>really? and why is that?
tru dat, i'm riding on tein coiovers too. they are sweet. stiff around corners but the dampening is so matched with the spring rate that the ride isn't harsh at all. can't go any better of a set up it u buy a shock that is designed for the spring and vice versa. mixing brands sometimes causes headaches.
but h&r race w/ koni yellows ride hella good too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by osuperjohno »</TD></TR><TR><TD CLASS="quote">I have an accord 99 4 door and I am wondering what gear to get. I was interested in getting h & r OE sport springs paired up with some KYB GR-2 shocks. If anyone knows a better set up that isnt to painful on my wallet or if i need anything else to ensure performance and safety, ie; cambering, bumpiness...
Thanks</TD></TR></TABLE>
We have the OMNI Power Full-Coilover for your 90+ Accords
THey start at $649 , plenty in stock, call us up to order or fro any tech info
http://www.robearracing.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wylie15 »</TD></TR><TR><TD CLASS="quote">CG's and AGX'x are a better combo than the tein ss</TD></TR></TABLE>
you sure?
agx=
i would pick SS over agx w/ GC'S
and of course nothing beats custom rate GC with KONI yellow
check out GC's AD damper system
they are revalvable
you sure?
agx=
they are revalvable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">and of course nothing beats custom rate GC with KONI yellow
they are revalvable</TD></TR></TABLE>
yeah.. i just finished installing custom valved ad's on an m3.. we upgraded from the koni yellows..
but that's waaaaaay over the daily driving requisite that osuperjohno is lookin for.
"tru dat, i'm riding on tein coiovers too. they are sweet. stiff around corners but the dampening is so matched with the spring rate that the ride isn't harsh at all. can't go any better of a set up it u buy a shock that is designed for the spring and vice versa. mixing brands sometimes causes headaches.
but h&r race w/ koni yellows ride hella good too."
the ride isn't harsh because of low spring rates and valving characteristics of the shock..high spring rates and agressively valved shocks will function well together but still give a rough ride regardless of it being a sleeve over or full coilover because they are both the same thing
[QUOTE=exr_pd],check out GC's AD damper system
they are revalvable[QUOTE]
gc ad is not meant to be used on the street..they are valed for smooth race tracks..they will break used on the pothole infested streets
and any shock can be revalved
Modified by azian21485 at 8:35 PM 12/30/2004
If you just want a comfortable ride for daily driving without breaking your wallet then get a nice set of springs and struts. Good springs would be Eibach, Neuspeed, H&R. Eibach will prob be the softest spring and most comfortable ride (I have the sportlines). Good shocks would be Koni Yellows or Tokico Illuminas. As someone said above me, the GR-2's are just stock replacements, wont do anything. Get some nice Koni's or Tokico's, you wont regret it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">you sure?
agx=
that is not correct...
comming from a owner that is riding on KYB AGX & H&R sport springs BTW.
you can't compare struts/shocks matted with a coil-sleve that is not made for that strut/shock...TEIN is a true coilover system, GC matted on some other companies struts/shocks are not and thus the ride quality will suffer and more importantly not perform optimally.
agx=
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CDEEE5 »</TD></TR><TR><TD CLASS="quote">
it doesn't matter if it's a true coilover system or not..shocks of perform the same duties and springs perform the same duties..they are both made of the same components
as long as a shock is valved with high enough numbers to dampen the springs, it is an optimal setup..this is all a shock does: dampen springs
all springs do is control how far a car will roll during cornering, braking and accelerating
what differs between shocks is HOW they are valved....how they differ on the shock dyno and at what speeds provide the most dampening will affect how a car rides and handles
when people say "coilovers are best because the shocks are valved perfectly to match the spring rates" this doesn't make sense at all..if this were true why would companies like tein offer higher or lower spring rates given the same valved shocks?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azian21485 »</TD></TR><TR><TD CLASS="quote">it doesn't matter if it's a true coilover system or not..shocks of perform the same duties and springs perform the same duties..they are both made of the same components
when people say "coilovers are best because the shocks are valved perfectly to match the spring rates" this doesn't make sense at all..if this were true why would companies like tein offer higher or lower spring rates given the same valved shocks?</TD></TR></TABLE>
hey I know you
remember CLAC?? you still got a accors?
hey I know you
i orignally planned on atein suspension for my 93.... then a front spring broke. with what money i had i got tenzor adjustable coilovers(ebay) tehy are stiffer then stock and i got the agx. with my strut bars front and rear my car does great. i lowered it an inch. its a cheap setup but it does alright id say go with a tein setup though
personally any good name brand full coilover pachage will ride good for street driving, plus you can put it on the highth you want your ride to be at. If you could get ahold of some apexi ws i heard they are good, but they are not made anymore. So you will have to look on ebay or in the classified sections of forums
Mitchell
Mitchell
Are you high or something? Tein SS would put that GC/AGX combo to shame.
hey I know you
remember CLAC?? you still got a accors?</TD></TR></TABLE>
i remember you too
clac has gone down the drain tho so i hardly go there anymore...still driving the accord and will be for some time
hey I know you
i remember you too
for street use all you need is a set of agx's and springs. i have agx's with suspension techniques springs... and theyre great. theyre not gonna ride like a $1000 suspension, but then again, youre not paying that much either.
