turboing a lude
Old Dec 29, 2004 | 01:05 PM
princeperfect003's Avatar
Default turboing a lude
i've heard that you have to remove your air conditioning system from your car in order to make room for the turbo kit, if i bought a turbo kit for my car would i have to remove any parts like the ac or the powersteering?
Old Dec 29, 2004 | 01:08 PM
Hawkze_2.3's Avatar
Default Re: turboing a lude (princeperfect003)
Hmmm......well, if you buy a manifold that is AC compatible, then you won't have to remove the AC. If you buy one that is not AC compatible, then you'll have to remove it. You'll also more than likely have some AC lines very close to some exhaust piping, so you'll have to protect those lines...
Old Dec 29, 2004 | 01:34 PM
Boost Addict's Avatar
Greddy and rev hard are both AC compatiable.
Old Dec 29, 2004 | 01:52 PM
92hondalude's Avatar
don't forget to build up the motor. If you don't know what to build up use the search function
Old Dec 29, 2004 | 03:02 PM
LudaMan's Avatar
Look what I can do!
Default Re: turboing a lude (92hondalude)
its possible to keep a/c, but more than likely if you dont buy a compatible kit, or go custom, you will have to re route some hoses.
Old Dec 29, 2004 | 05:30 PM
ludelvr's Avatar
Default Re: turboing a lude (LudaMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudaMan &raquo;</TD></TR><TR><TD CLASS="quote">its possible to keep a/c, but more than likely if you dont buy a compatible kit, or go custom, you will have to re route some hoses. </TD></TR></TABLE>
I went with a custom manifold and I kept my AC. Too bad I learned the hard way just how hot the manny gets!! haha ,mind you that was about 5 or 6 years ago...nothing is more frightening than having you hood off and seeing a nitors purge valve releasing then realising that you don't have nitrous!!!
anyway, Myine is a log style manny like the Fmax...works fine, but I just used some extra heat wrap and reflective coating around the lines closest to the manny.
Old Dec 29, 2004 | 10:05 PM
preludeez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">don't forget to build up the motor. If you don't know what to build up use the search function</TD></TR></TABLE>
building up your motor is not necessary for adding a turbo, plenty of people have successfully ran at a safe psi without build ups. of course a proper build up will allow you to run at higher psi though.
to the poster, as others have mentioned - you dont have to lose you ac or ps when adding a turbo, it will largely depend on the manifold you decide to go with.
BMRALR
Nov 4, 2007 02:37 PM
99fbpem1
Oct 13, 2007 05:52 PM
661rex89si
14
Oct 27, 2006 04:03 PM
type Gendy
Feb 26, 2004 12:31 PM
boondockgtr
10
Oct 30, 2003 07:06 AM
