b16 stock bottom end dyno results!
Old Dec 29, 2004 | 11:27 AM
realfasthonda's Avatar
Default b16 stock bottom end dyno results!
well i got my car dyno tuned this week and just got the charts emailed to me so i thought i post them up. im pretty happy with the results considering my setup and the tuner and tuning time.
2 hours of dyno time with a new tuner that has only been tuning for like 2 months and was just messing with af ratio, cams were not messed with and either was the timing.
mod list:
obd0 b16
all skunk2 valvetrain
skunk2 stage 1 exhaust cam
ctr intake cam
mild port work
2 layer headgasket
AEM pipe with a velocity stack on the end
B&M fpr
dc 4-1 header
gutted cat
apexi ws exhaust
tuned with hondata stage 2
IN THE WORKS:
tech 43 stroker motor
AEBS intake manifold
65mm tb
some sort of better header
Old Dec 29, 2004 | 11:39 AM
RobbieG35's Avatar
12 Years Strong
Default Re: b16 stock bottom end dyno results! (realfasthonda)
Damn good numbers for a stock block
Old Dec 29, 2004 | 03:15 PM
alecjoesph's Avatar
Default Re: b16 stock bottom end dyno results! (HybridHatch88)
nice curve
Old Dec 29, 2004 | 03:38 PM
Mr.OB*GYN_Rhett's Avatar
Default Re: b16 stock bottom end dyno results! (alecjoesph)
not bad at all and yeah smooth
Old Dec 29, 2004 | 05:02 PM
DIFFUT'S INC.'s Avatar
Default Re: b16 stock bottom end dyno results! (EkNineSpooner)
whats the numbers i can't see they too small ?
Old Dec 29, 2004 | 05:09 PM
Default Re: b16 stock bottom end dyno results! (DIFFUT'S INC.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIFFUT’S INC. &raquo;</TD></TR><TR><TD CLASS="quote">whats the numbers i can't see they too small ?</TD></TR></TABLE>
yeah sorry about that i know the graph's are pretty small
173 hp
122 tq
i was really suprised with the torqe numbers pretty good for b16
Old Dec 29, 2004 | 05:58 PM
Dstretch33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realfasthonda &raquo;</TD></TR><TR><TD CLASS="quote">
173 hp
122 tq
i was really suprised with the torqe numbers pretty good for b16</TD></TR></TABLE>
DAMN SKIPPY
Old Dec 29, 2004 | 08:07 PM
willyboyK20's Avatar
what compression u running with the two layer headgasket.?
Old Dec 29, 2004 | 10:36 PM
Default Re: b16 stock bottom end dyno results! (willyboyD16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willyboyD16 &raquo;</TD></TR><TR><TD CLASS="quote">what compression u running with the two layer headgasket.?</TD></TR></TABLE>
stock is 10.2:1 so like 10.4:1
Old Dec 29, 2004 | 10:41 PM
rjay8604's Avatar
Damn! thats a damn impressive b16.
Old Dec 30, 2004 | 07:07 AM
ce's Avatar
ce
looks good man
Old Dec 30, 2004 | 07:55 AM
n1div's Avatar
You got a very healthy motor. I'm pretty surprised at your torque. What's your vtec x-over set at?
Also, what does "mild port" consist of?
Great numbers and your power should still climb close/after 8k when you get the tb and im.
Old Dec 31, 2004 | 11:07 AM
Default Re: (n1div)
vtec cross over is at like 5500
the mild port work was done by a local shop that dropped the ball on some work they were doing for me so he did some port work to make up for it. so i know he didnt spend a ton of hours on it.
the intake manifold and tb are coming very soon so we'll see
Old Jan 3, 2005 | 09:28 AM
Default Re: (realfasthonda)
thanks for the compliments guys
Old Feb 23, 2005 | 09:23 PM
supertran25's Avatar
i was thinking about going with a similar setup. Nice numbers
GEN2 LS
K Series
Jul 25, 2014 04:21 PM
spec_v_kid
18
Mar 10, 2011 08:36 PM
BMo Tuning
13
Feb 7, 2008 12:42 PM
b16bluef
May 26, 2005 11:29 PM
athoughts
Feb 6, 2005 04:23 PM
