shift lite install need help asap
ok so im installing a shift lite into my 91 ls, it is mounted in the place of the cigar lighter, its a 3 wire hook up power, ground, and tach wire, i am really confused about wich wire to splice into by the ecu ? does any one know this, or does any one have a pic of a b18a ecu (plug side) and that could post it with a little dot on the pin that i need to use? please any help at all would be great i am completely stuck on this and there isnt anything i can do untill i get this last wire hooked up
when i did mine, tapped into the blue wire with silver paint stripes on it that is behind the guage cluster. i dont know if it is the same on your year car. If your car is OBD1 (gray plug) the rpm signal is third pinnout from the right on plug A in the top row. If it is OBD0 (yellow/clear plug) it is plug B third from right on the top row. remember this is all on the ecu side.
http://www.turbod16.com/viewtopic.php?t=3572
wich pin would it be, if you scroll down the page alittle you will find the ecu for my car if you could put a dot or something on the wire i shold tap into it would help out alittle more
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLStuner »</TD></TR><TR><TD CLASS="quote">when i did mine, tapped into the blue wire with silver paint stripes on it that is behind the guage cluster. i dont know if it is the same on your year car. If your car is OBD1 (gray plug) the rpm signal is third pinnout from the right on plug A in the top row. If it is OBD0 (yellow/clear plug) it is plug B third from right on the top row. remember this is all on the ecu side.</TD></TR></TABLE>
b15...
is what hes saying
b15...
is what hes saying
thanks guys i just went ahead and spliced into the blue wire on the distributor and tie strapped the wire to my amp power wire and ran it str8 through the hole i had drilled for that..
Nicaraguense13
Jul 28, 2008 12:21 PM
