Help on Torque SPECS for lower front control arm bolts
Old Dec 29, 2004 | 10:59 AM
jdmspoonitr's Avatar
Default Help on Torque SPECS for lower front control arm bolts
For one reason or another the Helms fails to tell me these two torque specs. I'm sure one of you guys knows so let me know.
It's these two in the picture below.
Old Dec 29, 2004 | 11:40 AM
viprcr1's Avatar
Default Re: Help on Torque SPECS for lower front control arm bolts (jdmspoonitr)
just make sure they are tight
Old Dec 29, 2004 | 11:45 AM
PM-Performance's Avatar
Default Re: Help on Torque SPECS for lower front control arm bolts (viprcr1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viprcr1 &raquo;</TD></TR><TR><TD CLASS="quote">just make sure they are tight </TD></TR></TABLE>
exactly.
Old Dec 29, 2004 | 01:35 PM
4U2NV's Avatar
I think you tighten those to German Specs... Gootentite...
Old Dec 29, 2004 | 02:02 PM
cxSHOE's Avatar
i had to find out while doing my brake swap/s and dealer mech. said they tighten it to the same amount as the radius arm bolt at 67ftlbs.
even they have no updated spec notice on that part of the car as far as torque goes.
i've had no problems taking it apart after toque as well. and no sign of strain or cracks in the arm. and ive done the swap about 3 times in the past year. so you should be good. and i torqued it with the car up and not loaded on the ground.
B2FiNiTY's Avatar
It is in the helms. If I had mine here I would tell you.
Old Dec 29, 2004 | 02:36 PM
JDMluvR's Avatar
Default Re: Help on Torque SPECS for lower front control arm bolts (4U2NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV &raquo;</TD></TR><TR><TD CLASS="quote">I think you tighten those to German Specs... Gootentite... </TD></TR></TABLE>
LOL
Old Dec 29, 2004 | 02:50 PM
mstewar's Avatar
Default Re: Help on Torque SPECS for lower front control arm bolts (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">It is in the helms. If I had mine here I would tell you. </TD></TR></TABLE>
i sure didn't see them a month ago when i was swapping mine..
i set them to 67 ft lbs..
Old Dec 29, 2004 | 03:01 PM
uNF$@#!'s Avatar
Default Re: Help on Torque SPECS for lower front control arm bolts (mstewar)
dont forget the antiseize on it
Old Dec 29, 2004 | 04:00 PM
B2FiNiTY's Avatar
Default Re: Help on Torque SPECS for lower front control arm bolts (255.255.255.255)
It is in there. POSITIVE. 67 seems much too high. I remember it being, 36 ft/lbs, 42 ft/lbs or 48 ft/lbs.
Old Dec 29, 2004 | 05:04 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">It is in there. POSITIVE. 67 seems much too high. I remember it being, 36 ft/lbs, 42 ft/lbs or 48 ft/lbs. </TD></TR></TABLE>
let us know what page... ive looked at both civic and integ helms manuals and nowhere to be found... maybe they are in a different section not in the suspension part???
Old Dec 29, 2004 | 09:07 PM
ITR#132's Avatar
Just make sure its tight and youll be fine.
If you really want to torque it; It will be the same foot lbs. as another bolt/nut the same size as the one your trying to torque.
Old Dec 29, 2004 | 09:17 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (ITR#132)
at my dealer, and most dealers for that...we just hit it with a couples wacks of a low torque impact.
But when taking care, I go 65 ft lbs and NEVER have had a problem.
Old Dec 30, 2004 | 01:01 AM
B2FiNiTY's Avatar
Default Re: Help on Torque SPECS for lower front control arm bolts (cxSHOE)
I'll check it out tommorow and take a pic of the page.
Old Jan 10, 2005 | 05:28 PM
B2FiNiTY's Avatar
I'll be darned! I was putting my tranny back on last weekend and couldn't find the tq specs. I stand corrected.
Old Jan 10, 2005 | 05:41 PM
1Quikgsr's Avatar
gun that bitch down
That_Delsol_Guy
Dec 30, 2015 05:55 AM
Hunter
Feb 17, 2011 06:31 PM
civic46
Apr 28, 2010 05:43 AM
ef-it90
Mar 7, 2009 04:26 PM
jacob1217
Aug 23, 2007 05:05 PM
