TRanny ?s hydro gears and shafts in a cable tranny
Old Dec 29, 2004 | 10:07 AM
swaytec360's Avatar
Default TRanny ?s hydro gears and shafts in a cable tranny
i have a cable ls tranny that i want to put hydro b16 or gsr gears and maybe shafts into
is this possible thanks
Old Dec 29, 2004 | 10:35 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: TRanny ?s hydro gears and shafts in a cable tranny (swaytec360)
check out the gearspeed link in my signature they can answer all of your questions
Old Dec 29, 2004 | 05:02 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
yes, if you have the 92-93 casing. you can use shift forks 1/2 and 5/r...you need a (itr, b16, gsr) 3/4 shift fork since the sleeve on those trannies are little bigger than the ls.
Modified by not so civic at 6:12 PM 12/29/2004
ill_wills_da9
Mar 26, 2009 11:51 PM
widebodyeg
Jan 29, 2008 11:12 AM
arielmalespin
Feb 15, 2005 08:41 PM
tncivic-dvsb
Oct 30, 2003 07:29 PM
