cel 14...can it be caused by...
Old Dec 29, 2004 | 08:57 AM
jman30513's Avatar
Default cel 14...can it be caused by...
can a cel 14 (iacv) be caused by anything else?
vacuums or maps....anything but a iacv?
98 civic ex
thanks all
jman
Old Dec 29, 2004 | 08:59 AM
Luserkid's Avatar
Default Re: cel 14...can it be caused by... (jman30513)
Could be caused because its dirty. Take it off and put some carb cleaner on it, reset ecu and try again
Old Dec 29, 2004 | 09:02 AM
jman30513's Avatar
Default Re: cel 14...can it be caused by... (Luserkid)
cleaned it three times
when using the stock ecu the cel comes on sporadicly but my idle is everywhere
when i pop my p28 in with ubers map, cel 14 comes on fast
i guess the iacv could be bad right?....but i have cleaned it
any other way to check it out?
Old Dec 30, 2004 | 05:19 AM
jman30513's Avatar
bump please
Old Dec 30, 2004 | 07:22 AM
FredoSP's Avatar
probably the IACV is getting stuck or something, can u switch it out with a friend to make sure its that?
When u clean it, did u take compressed air and blow everything out? Do you have the "8" shaped gasket? Is there anything in the screen? Anything blocking it on the back of the intake manifold?
Old Jan 1, 2005 | 07:33 AM
jman30513's Avatar
yeah it has the figure 8 gasket and i did blow it out
when the cars idling i can unplug it ano nothing changes....doesnt change the idle at all
is this a sign?
Old Jan 1, 2005 | 07:52 AM
2lua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jman30513 &raquo;</TD></TR><TR><TD CLASS="quote">cleaned it three times
1 did you try to change the ivac
2 there is your problem. in bold letter
Old Jan 1, 2005 | 12:12 PM
jman30513's Avatar
no i havent tried another (no readily available where im at)
and ive used 3 different p28 bases that work with other cars....i do get the code 14 on my obd2 ecu but not as often
the iacv can be bad and not throw a code right?
jman
gsr-2nr
Jan 2, 2008 08:31 PM
Aquafina
Jun 10, 2007 05:34 PM
tweekerz
Nov 27, 2006 03:22 AM
B00ST2nR
Apr 18, 2003 04:03 PM
