larger Throttle body ?
Old Dec 29, 2004 | 08:09 AM
fliP's Avatar
Default larger Throttle body ?
I know it's kinda dumb but hey what happens if i swap my tb to a larger one ?
Old Dec 29, 2004 | 08:13 AM
b16ahybrid's Avatar
Default Re: larger Throttle body ? (fliP)
You can potentially have more air flow into the the motor assuming you have the mods to accomodate it. Less of a restriction.
Old Dec 29, 2004 | 08:14 AM
JDMlyfestyle's Avatar
if you go to big you can loose horsepower because ull be losing the velocity. it really all depends on your setup.
Old Dec 30, 2004 | 06:32 AM
fliP's Avatar
Default Re: (JDMlyfestyle)
My B18c5 has 60mm . I wanna increase to 62mm. Will this be bad ?
Old Dec 30, 2004 | 10:13 AM
92civicb18b1's Avatar
Default Re: (fliP)
It won't hurt, i bored my TB a bit, made a difference in Throttle response.
Old Dec 30, 2004 | 10:28 AM
snatch's Avatar
Default Re: (92civicb18b1)
You do need to make sure you port match the intake manifold as well.
lilboxx
Apr 16, 2012 08:27 AM
g0tgot
Aug 26, 2007 04:57 AM
quikflip27
Welding / Fabrication
Jun 5, 2007 06:20 PM
HSPxNick
Oct 11, 2006 08:38 AM
allnaturalb16
Sep 26, 2006 02:09 PM
