LS oil filter mount...pressed or threaded?
Old Dec 29, 2004 | 07:24 AM
JapanExpress's Avatar
Default LS oil filter mount...pressed or threaded?
is the LS (B18A) oil filter mount pressed into the block or is it threaded?
the gsr has an oil cooler, and if the mount is threaded, we can take out the one on the ls motor and just pop the one from the gsr in there
Is this right? My friend is building an ls/vtec. GSR parts are coming off a 95 b18c.
Old Dec 29, 2004 | 05:46 PM
Default Re: LS oil filter mount...pressed or threaded? (JapanExpress)
bttt
Old Dec 30, 2004 | 08:07 AM
anyone know?
Old Dec 30, 2004 | 09:04 AM
MAV3RiCK478's Avatar
the oem oil coolers center bolt threads over the blocks center bolt. just make sure to replace the gasket between the oil cooler & block and use all the hoses and connecting pipe, new o-rings, thermostat housing from the gsr block. i think that is it?
tobe1424
Sep 15, 2006 09:31 PM
11SEC CIV
Feb 22, 2005 06:53 PM
Huee
Apr 28, 2004 12:24 AM
jdmhatch94
Apr 29, 2002 08:21 AM
