Air Conditioner filter
Old Dec 29, 2004 | 07:12 AM
NealPT's Avatar
Default Air Conditioner filter
Where is the air conditioner filter located on a 2001 Honda accord?
Thanks!!
Old Dec 29, 2004 | 08:08 AM
eauto's Avatar
Default Re: Air Conditioner filter (NealPT)
The air conditioning filter, also known as Cabin filter is located on the passenger side, behind the glove box. If you do search for this forum, you should be able to find DIY instructions for replacement.
Remeber, you will need two filters, as they come in pairs. I change them every 30,000 miles.
Old Dec 29, 2004 | 08:21 AM
NealPT's Avatar
Default Re: Air Conditioner filter (eauto)
Thanks a bunch. I knew it was in an obvious place because I had looked in all the obvious places.
Old Dec 29, 2004 | 08:31 AM
Heat's Avatar
No, it's not an obvious place. I changed mine in my '99 LX at 30,000 miles, it was barely even dirty, I'm not changing it again until 90,000 miles (currently I'm at 70,000 miles). It is a pain in the (butt) to get to, and the last step is trying to get it out (and the new one back in) from behind a metal bar or two.
Definately do it at least once, but you will need instructions. I highly recommend picking up a Haynes manual for your car (maybe $14 from Pepboys, Autozone, etc), it will tell you how to get to it as well as other things for your car.
If I remember right, it took me about 30 minutes to change it and put the car back together.
globy123
Apr 3, 2010 09:03 PM
derekcentrico
Dec 12, 2009 11:38 AM
hondateg08
Honda Civic (2006 - 2015)
24
Apr 15, 2009 10:09 AM
RickyJa
Acura TL, RL & ZDX
Feb 19, 2008 08:03 PM
