Garrett .63 or Precision SC50??? Both almost the same price but which to get???
My friend in sc can get a garrett .63 trim for 550 shipped but someone on ht has the precision sc50 for 595 shipped........Which to choose? arent they the same thing?
Modified by jh at 4:31 PM 12/29/2004
.63 isn't trim, it's the A/R ratio of the housing to wheel. Did you mean 60-trim vs. 50-trim?
a 57 trim is slightly bigger, where as the SC50 is a 50 trim, its up to you which turbo you want to choose. they are built practically the same.
The SC34 has a 57 trim wheel (56mm diameter, 2.320" inducer/2.950" exducer) on the compressor side and either a 69 or 76 trim wheel on the turbine side, so there are actually two different versions of the 57 trim.
Also, don't get too hung up on buying a turbo based on the trim size. Compressor trim is a mathematical calculation, which is Inducer Diameter squared divided by Exducer squared X 100. The point is, there's more than one different way to go thru this equation to come up with a 57 trim. Example: 3+3 = 6, 4+2=6, 5+1=6, etc. You can also have different sized wheels with the same trim.
Hope that sheds some light.
Rod Short
Sales Manager
Precision Turbo
Rod Short
Sales Manager
Precision Turbo
underpressure02
Feb 10, 2004 07:26 AM
