clutch pedal is DEAD
i wake up to start my car this morning and my clutch pedal is dead. falls flat to the floor with no resistance and doesnt spring back up.
this is not new. it has happened the past two winters and i think the cylinder down by the pedal is leaking. i can see the rubber piece has fluid on it.
usually when this happens, i pop the hood, see that the fluid is empty, fill it up, and pump the pedal for about 10 mins and its back to normal.
not today.
i filled the fluid back up and went to pumping. AN HOUR AND A HALF LATER, still no feeling in the pedal. it still drops straight to the bottom and wont pop back up.
not today.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 »</TD></TR><TR><TD CLASS="quote">its probably time to change out your master and slave cylinders</TD></TR></TABLE>
BUMP!!! When my clutch went out I had to change the master cylinder and the slave.... our prelude as very bad clutch systems
either that or the rubberish hose that connects to your slave cylinder on ur tranny ,that had a huge leak on mine and htat's all i had to replace
pair8hd
16
Mar 11, 2020 06:40 PM
kulrevon
Oct 24, 2006 04:22 AM
gsr1289
Aug 22, 2006 07:11 PM
T3T495GSR
Aug 18, 2003 01:08 PM
