Air Filters
Old Dec 29, 2004 | 06:01 AM
deechiguy's Avatar
Default Air Filters....?
I run K&N filters in both my Honda's and now I am reading they might not be the best choice. So I started some research and was reading about WIX fitlers...Any ideas on these filters? Or any recommendations?
Thanks!
Modified by deechiguy at 12:09 PM 12/29/2004
Old Dec 29, 2004 | 08:10 AM
deechiguy's Avatar
Default Re: Air Filters....? (deechiguy)
I went out and bought two WIX air filters for my cars. My Accord runs smoother and more powerful with the WIX filter. It was immedaite difference. My car idles like its not even running....
Old Dec 29, 2004 | 08:15 AM
PreStaged12s's Avatar
What the heck is a WIX filter? where did you find it, how did you hear about it?
Old Dec 29, 2004 | 01:41 PM
deechiguy's Avatar
Default Re: Air Filters....? (PreStaged12s)
I found it on http://www.bobistheoilguy.com . I got hooked on filters from Honda-Tech and started using Filtech OEM filters. Then I decided I would look into air filters. On http://www.bobistheoilguy.com they were talking about K&N not totally filtering the air. So I started reading the forum the most recommended filters were OEM, WIX, and Pureolator. So, I looked up WIX online http://www.wixfilters.com . I have seen where people on Honda Tech use WIX oil filters. So I thought that I would try. My car runs smoother and stronger with the WIX filter. They are not reusable, so after X miles you have to replace it. Mine was around 15 bucks.
Hope this helps!
Old Dec 29, 2004 | 05:09 PM
Dstretch33's Avatar
O really gotta look into this
Old Dec 29, 2004 | 05:26 PM
deechiguy's Avatar
Default Re: Air Filters....? (Dstretch33)
there is some study on the http://www.thedieselstop.com I havnet found the study yet.
I will look into it and post...
Modified by deechiguy at 9:49 PM 12/29/2004
Old Jan 1, 2005 | 01:45 PM
deechiguy's Avatar
Replaced the K&N with Wix in my CR-V and had the same results. It runs smooth and stronger with the Wix brand than with the K&N. I am going to track mpg stats and post later....
Old Jan 1, 2005 | 06:30 PM
Odiedogcx's Avatar
AIRBORNE
Apex'i filter .. good power and good filtration. it's dry and doesn't need to be oiled and cleaned.
outperformed the k&n, hks, and blitze in both HP and filtering properties.
http://mkiv.com/techarticles/filters_test/2/
Modified by Odiedogcx at 10:40 AM 1/2/2005
rsangha13
Apr 24, 2013 06:42 AM
RedlineMotive
17
Sep 3, 2009 05:56 PM
traumatized
May 31, 2004 10:40 AM
KiNG $h!t
Mar 16, 2004 06:34 AM
yasir4u
Nov 8, 2003 12:11 AM
